Page 1176 of 1380 <123 ... 117511761177 ... 137813791380>
Alex L
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Alex1976 wrote:
Popped along to the Caffeine and Machine Winter Weapons meet. So nice vehicles there to admire and a great atmosphere to enjoy too.
I was there in my Defender this morning and then decided to return a couple of hours later in another car that’s not been out since December.
And I got an Insta mention by them
Untitled by Alex L, on Flickr
Post #757665 10th Feb 2019 12:02am
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Retroanaconda wrote:
Adam17 wrote:
Ah ok then... you do a lot of miles then...? lol
About 36k p.a.
If your steering is off centre it might just be a case of the steering wheel being put on wrong or you may need to adjust the drag link.
Before I changed the boss and steering wheel, the original had lots of play in it, so it wasn't noticeable...
When I changed the boss and steering wheel to optimil/momo, the steering wheel sat slightly 'turned' to the left... I took it off, repositions one spline over - then it was way out to the right... I fought over this for a few days in between drives, repositioning between the splines, but made no difference..
Ill have a look at the drag link. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #757693 10th Feb 2019 9:34am
Nigelpugh7
We had a full day of off road school, then a trip to Caffeine and Machine for their winter hacks meet.
Then an evening of customers enjoying our “ Midnight Drives” back at our Woodland course.
Post #757737 10th Feb 2019 12:42pm
Retroanaconda
If it’s only a spline out (or half a spline, hence trying to find a place between two adjacent positions) then you can fix as follows:
1. Firstly ensure tracking is correct, i.e. toe setting is as desired. I always set mind straight ahead so the front wheels are parallel with the rears. Some string is all that is required to do this.
2. Set wheels in dead ahead position.
3. Slacken the clamps or locknuts on both ends of the drag link*
4. Ensuring the wheels do not move, turn the drag link slightly to move the steering box drop arm left/right as required in order to tweak the steering wheel to the central position.
5. In theory this should also leave the steering box centralised (denoted by the slot at the back of the drop arm), though in practice if this is very slightly out it’s no biggie.
6. Ensuring that the ball joints both ends are in the ‘neutral’ position, retighten the clamps or locknuts.
7. Test drive. Repeat adjustment if necessary.
* If your drag link has not been adjusted for some time this can be a big problem, requiring removal from the vehicle and application of heat and oil to free it up on the bench. If in doubt buy a new ball joint for the axle end so that it can be sacrificed in this process.
Post #757775 10th Feb 2019 2:59pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Took it to the Harwell ARS Rally at Didcot.
Unfortunately it was a marshalled car park in a school playgound so didn't get to park next to the other 3 defenders that were parked up for the event. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #757801 10th Feb 2019 5:44pm
Alitaff
Hi,
Bought an Exmoor chubby box on EBay and managed to fit it today.
Great upgrade and driving position is much more relaxing.
Although it wasn’t straight forward since I had to raise the box by 45mm to clear the electrical boxes under he chubby box.
Appreciate if You can help me out with couple of questions!
1- Are the electrical boxes under the box diagnostics?
2- On the passenger seat you will see the cables for the dual USBs on the chubby box but I am not sure how to connect them!.
I have attached a photo of the connectors, sorry for the poor quality, it was getting pretty dark!
cheers.
Here are some photos including before and after to see the difference in the height🧐
Post #757802 10th Feb 2019 5:45pm
VVS210
Took it for one last drive then sold it so now Defenderless Shocked
Post #757806 10th Feb 2019 6:11pm
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Post #757809 10th Feb 2019 6:22pm
landy andy
Alitaff wrote:
Hi,
1- Are the electrical boxes under the chubby box for Diagnostics?
cheers.
What’s the boxes under the cubby box? They aren’t standard stuff
Post #757821 10th Feb 2019 7:17pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Temporarily I hope 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #757832 10th Feb 2019 7:47pm
Alitaff
Hi Landy Andy,
Thanks for the input.
Mystery is solved, cheers 👍
Post #757844 10th Feb 2019 8:14pm
wyvern
Alitaff - ^^^ maybe you should edit your post to say ‘Ive just found out what ti was and tis all ok’ .... Whistle Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #757846 10th Feb 2019 8:21pm
Alitaff
Hi wyvern,
Question 1 has been resolved and this is now been highlighted in my post.
Question 2 is still on th table 🧐
Post #757864 10th Feb 2019 8:59pm
Sulisuli
Alitaff what wyvern was suggesting was not to divulge on a public forum whereabouts your tracker is located on your Defender
You never know who reads these forums Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #757865 10th Feb 2019 9:03pm
Alitaff
Sulisuli, thanks for putting me on the right track.
Wyvern, thanks for your concern.
I have edited my last post 👍
Post #757868 10th Feb 2019 9:19pm
