Home > Puma (Tdci) > Puma going into limp mode
bvandyk
Lets list all the reasons there are for a Puma to go into limp mode..
I have a friend with a 130. Remapped and upgraded intercooler, but goes into limp mode from time to time when driven hard. (even on cold days) Everything works normal, but just can't exceed 60km/h when this happens.
Reason 1 can be: Faulty / Dirty MAP sensor
Please add possible reasons.
Post #233755 8th May 2013 10:44am
Laurie
Clogged radiator internally
Ditto externally.
Post #233756 8th May 2013 10:48am
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Borken turbo pipe(s)
Post #233760 8th May 2013 11:00am
bvandyk
But will this be intermittent then?
Post #233761 8th May 2013 11:04am
Naks
You guys probably won't believe this, but a local Puma goes into limp mode when driving past an Air Force base, most likely due to interference with the immobiliser:
Quote:
Please help me to explain a very strange Puma behavior, which happened now twice exactly on the same stretch off highway (N1 along Ysterplat Air force Base, Cape Town) two weeks apart:
Driving at 100 km/h suddenly the speed decreases to 80 km/h and one can feel there is simply no power to accelerate. This condition remains until the engine is switched off, then all is back to normal.
I might add there are no warning lights, no abnormal noise, no smoke, nothing. The road is level, the truck was not loaded and had enough Diesel in the tank.
Post #233764 8th May 2013 11:20am
The only time (sofar) mine's gone into limp mode, due to a leaking pipe from turbo to intercooler, I couldn't get anywhere near 60kph! It was closer to 25kph.
Does "limp mode" limit the truck to different maxima depending on what's wrong?
Post #233765 8th May 2013 11:23am
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Q068 Software Update
Happens with cold weather.
http://www.defender2.net/forum/topic1834.html?highlight=q068 Janusz
www.yahodeville.com
Post #233783 8th May 2013 12:45pm
bell-auto-services
Any fault codes in the car ?
Post #233789 8th May 2013 1:25pm
bvandyk
Don't know yet. He is not close to me to go and check. But he drove around today for about 50km and experienced no issues.
If I can get to him I'll plug my UltraGauge in and see if it picks up any fault codes
Post #233790 8th May 2013 1:28pm
iruffell
It was on mine, took 5 visits to the dealer to diagnose
Post #233791 8th May 2013 1:33pm
