Home > Td5 > TD5 90 rear springs
stokerjones
2005 Defender 90 Td5 HT Epsom Green
TD5 90 rear springs
Have been lurking on here for quite a while and until now found what ive needed with a search.
But, the rear of my 90 is looking rather saggy. From searching around on here it apears that most are a little bit back end down.
As I'm running a brown church roof rack, 265/75/16s on steel modulars and about to fit a wheel carrier theres not much left in the springs and put stuff in it and its more or less on the bump stops.
From what i understand theres many options, progressive, HD, front from different models etc.
Im swaying towads progressive but some opinions and advie would be much arpeciated
Thanks in advance
Callum
Post #230581 25th Apr 2013 9:30pm
adseybear
Canada
Something like this would probably suit you..
http://www.flatdoguk.com/def-90-std%2Fhd-1~325 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #230763 26th Apr 2013 4:54pm
bob neville
I've got a pair of TF light load front springs here, only fitted on a 110 for two weeks.
https://www.terrafirma4x4.com/products_php.php?cat=14&grp=104
If somebody can confirm that they would be OK for the rear of a TD5 90 I can work out a price for you if you are interested.
2013 Defender 90 CSW - sold
Post #230771 26th Apr 2013 5:29pm
Welly911
Evening Bob,
How did these springs ride on you 110DC? I've also got a DC, mainly for use on the school run and dune bashing in the desert. Looking to change spring in the near future for a less firm ride... Are the TF ones good on/off road? Cheers Mike. P.S popping back to Yeovil area in a couple weeks if you have any leftovers . Thanks again
Post #230781 26th Apr 2013 6:19pm
bob neville
Hi Mike
With a winch on the front they were fine but I actually found the standard fronts suited my vehicle better with the winch. The TF's did add about an inch lift to the front with a winch, I was trying to compensate for the drop, but it would probably be more without a winch.
Not 100% sure how they would handle a non winch equipped vehicle.
Drop me a PM when you are back in the Yeovil area, we can meet up for a beer or two Thumbs Up
Post #230783 26th Apr 2013 6:34pm
Welly911
Cheers Bob, this visit is only a quick one. Visiting the folks and attending a cheeky reunion at Yeovilton. Will give you a shout when in the neighbourhood for a more usable period. The same offer is open to you if you pass through Dubai.
Post #230990 27th Apr 2013 5:35pm
