Home > Puma (Tdci) > has anyone had this leak ? |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 |
Got this same leak ... like you can't figure out where it comes from ...
The bulkhead/window frame seal here in Malaysia is done with silicones at the factory. I also sealed the rubber around the windshield. That has stopped it for the normal rains, but still returns when we have those tropical downpours here. As far as I can figure it out the water seeps through via the rubber around the windshield. Stephan |
21st Apr 2013 3:12am |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
I have this also.
I need the winscreen replaced so have purchased a new seal ready Will ask the guy to pump plenty of sealent in also to see what happens Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
21st Apr 2013 7:09am |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 719 |
I had this one and was easily resolved. It was the seal around the false hinges for air vents (puma). Resealed and no problems to date. I hope that helps
21st Apr 2013 5:01pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
windscreen frame to bulkhead seal 2.4 90 XS
25th Apr 2013 3:33pm |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
Window blocks? The gasket is terrible.
25th Apr 2013 4:41pm |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 |
Bulkhead to screen blocks is a good place to start - mine need doing, the blots/nuts are rusting on the inside 1953 80
1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
26th Apr 2013 3:43pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
thanks for the advice everyone
Last year I sealed the notorious 'gap' and windscreen rubber and put a thin bead of sealant around the windscreen hinges but it was a quick rough job (I got more on my hands). I need to do it again properly this time ! Good to know thats where its definately coming from |
26th Apr 2013 5:52pm |
