Home > Maintenance & Modifications > new windscreen Hinges on Puma 110
Page 2 of 2 <12
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi Steve E, the bubbling paint work was an inch above the hinge and between the rubber and window frame edge on the NS. They removed the glass and fitted new rubber seal, with silicone grease as if they had used sealant it would have been impossible to remove glass without breaking it if required in the future. I'm happy. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #235565 14th May 2013 9:27pm
WarPig
The underplaying hinge problems must lay with the hinges/brackets themselves rather than with the spray paint job that LR did on the production line.
The reason I say this is because 2-3 years ago I bought brand new genuine brackets and had them sprayed by a good spray shop when they the resprayed my 300tdi, and already they are showing signs of bubbling. It's as if they are made of a metal that just doesn't like paint?
Post #235717 15th May 2013 1:50pm
Page 2 of 2 <12
