Home > Technical > ESR254 - Rear Tailpipe and Silencer - 90 200TDI (1990-1993) |
leejunfan Member Since: 01 Jun 2012 Location: Kent Posts: 33 |
Took the Defender for MOT on Saturday and it passed with an advisory on the rear tailpipe as it was pitted and as the wife is away for the weekend thought i might as well use the time productively without getting moaned at.
So i thought i would change the rear silencer out with this http://www.paddockspares.com/esr254-rear-t...-1993.html I know it will probably need new nuts and Paddocks say that the central pipe it connects to has the bolts built in, does anyone know if that is correct? But i am not sure if there are any gaskets in between if so anyone know what the part number is or is it just a case of using the tube stuff. Thanks in advance! |
8th Apr 2013 4:29pm |
fitted it last weekend, bolts are on middle pipe plate, welded on with a blob of weld. One thing the pattern Brit-Part rear silencer plate is fixed, the middle pipe existing one was rusted in place so looked like they would not line up, a tap with a hammer loosened it up to fit and then it was easy to fit together.
20th Apr 2013 10:13pm |
