![]() | Home > Maintenance & Modifications > Fire + Ice sidesteps for £159 ! FITTED |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
If you want to drill 4 holes in the chassis. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4748 ![]() ![]() |
I'd be interested in seeing the new step and the old Paddocks one side by side to see how they differ.
Rossy, before you fit the new steps perhaps you should consider this http://www.flemingltd.com/coatings/ Might be worth a trip. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
OK I fitted these today. They're not stainless steel by the way but they seem good quality - at least as good as the Paddocks ones. Once fitted they sit closer to the vehicle, in line with the mudlaps so they look neat.
I found them difficult to fit compared to the last ones. Firstly me and homemade rivnut tools don't get on but I got there in the end. As ARC99 said you have to cut a lump out of the plastic tray fitted under the seat boxes so out came the Dremel then a jigsaw. I wasn't happy with the bolts that came with it. They're excellent quality but the thread stops 3/4 the way down so there isn't enough of it. I just used 13mm nuts, bolts and washers instead for the 8 holes connecting the top of the steps to the pre drilled holes in the extrusion from the floor. Now that they are fitted they look great. Very cheap and I'd highly recommend them to anyone who is thinking of buying them. Sorry no photo yet because the missus is out and she does all that uploading stuff (I've no idea) ![]() |
![]() Click image to enlarge Right she's back. There they are. (Killer I'd say you'd make decent margin on these !) ![]() |
Nice one.....
More functionality and better looking than the old ones when in comparison I'd say..... ![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() ![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
