Home > Technical > 2.2TDCi Smoothness (or not!)
Page 2 of 2 <12
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
J8GHX wrote:
Topix is the Jaguar Land Rover vehicle resource website. It shows vehicle build data, recommended fixes, recall info, instructions for fitment of parts accessories etc.
topix.landrover.jlrext.com/
Hope this helps?
If I subscribe for a day, can I download and save items from the site?
Post #223813 1st Apr 2013 11:09am
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
I did and downloaded a lot of stuff. Most is in PDF format
Post #223845 1st Apr 2013 12:42pm
Rakthi
Post #223846 1st Apr 2013 12:43pm
Tony
United Kingdom 2012 Defender 90 Puma 2.2 SW Keswick Green
J8GHX wrote:
The software download mentioned isn't automatically put on your vehicle unless you have a specific complaint which will it will cure. Low speed jerkiness and rough/poor high rev gear changes are two of the faults it cures.
It also cures a DPF fault, so call your dealer say you are having rough gear changes and they should put the software upgrade on.
I've had mine done, and it's like a different vehicle!
Get it done!
John
Thanks for that John, most helpful! I will definitely tell the garage about the jerkiness and gear changes (which can be fine some days and not so good on others) as the only outstanding Topix issue on mine is Q205 Charge Air Cooler Hose & Coolant Hose Spring.
Cheers! Thumbs Up
Tony
Post #223975 1st Apr 2013 7:38pm
J8GHX
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Hi Tony,
The field service actions are different to recalls and software updates.
Recalls are for a safety related issue and the manufacturer has to contact owners by law.
Field Service Actions are where the manufacturer chooses to make a modification to the vehicle to stop a problem happening which they're aware of and has affected many vehicles. They can do these whether the vehicle is under warranty or not. (It's worth checking every age of vehicle for outstanding service actions, my next door but one neighbour has just had nearly £1500 of work done to his 1994 P38 Range Rover, FoC as an outstanding action! He only found out after putting it in Topix and the dealer honoured it without question!!
Software Updates are not installed as a matter of course, like would happen on an iPhone for example. They can be applied to help rectify a fault or symptom, but if the car doesn't need it or the owner hasn't complained, it won't be installed. It's a bit like an antibiotic. You get a specific type for a specific problem!
John. Currently....... all gone...... pending delivery of a mid life crisis.......
Previously..... Quite a few! I really am a sucker for them!
Post #224022 1st Apr 2013 10:17pm
borderterrier
[quote="J8GHX"]PS it's applicable to some 13MY also.
You'll find details of the software patch on Topix, and it shows the chassis number range which it's useful for.
John[/quote
Which ref number is it, the only one I can find is to do with flat spots when changing gear, nothing specific to slow speed jerkiness or and DPF faults?
Post #226194 10th Apr 2013 11:40pm
Photoguy1510
New Zealand 2013 Defender 110 Puma 2.2 SW Orkney Grey
New software for my13 110 release note 17 April 2013- do we get a smoother ride without kangaroo jack under the bonet?
Is there any way to see what is addressed by this update? 2013 Orkney Grey 110 SE on order should be here on 20/04
Post #228461 18th Apr 2013 9:50am
Page 2 of 2 <12
