Home > Puma (Tdci) > Warranty work - usual suspects |
Paint peel from the inside of the arches is common but I've not seen it creep into the exterior finish. Steve.
12th Mar 2013 5:12pm |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1223 |
Yup...paint off the inside of my spats too.
Dealer said its the way I washed it...shouldn't use a jet wash!? When I collected car...there they were washing it with a jet wash! Sometimes there is just no reasoning!! Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
12th Mar 2013 5:15pm |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 |
I'm guessing I'll get the same, ironic as I've not used a jet wash on it, must've been when it was at landrover Darren |
12th Mar 2013 6:40pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Common problem.
The inside of the spats are normally not painted, what paint is there is over spray. The insides are not prepped to take paint so the over spray will just flake off. Happened on my 110 but it never affected the outside of the spat. Had the 110 checked by a very good paint shop local to me and he confirmed it was normal, they do a lot of work on Defenders, and then they promptly removed all the flaking paint so I could not complain Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
12th Mar 2013 8:42pm |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
also check the rear sliding window catches - i had blistering appear on mine
14th Mar 2013 10:09am |
4 new mud flaps and brackets (only needed 3!) fitted, bumper, rear step, headlight surrounds and front grill done without quibble
Need to shine up the rear crossmember now as it looks dull compared to the new bits Darren |
23rd Mar 2013 8:31am |
canterkid Member Since: 16 Mar 2013 Location: norfolk Posts: 13 |
paint falls off from inside wheel arches,i try not too wash outside too hard in fear of paint coming off!
23rd Mar 2013 3:51pm |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 |
Front bulkhead (although Land Rover tried to say it was stonechips), 2 mirror arms, 2 headlight surrounds, clutch & slave cylinder, oil leak behind the injector pump, complete central locking system, Heated Rear Screen, front wheel bearing & drive shaft.
Not good for Land Rover, this is 3.5 weeks work in the last 3 months! |
2nd Apr 2013 8:12pm |
And it's booked in for a rear wheel bearing and something major in the steering, either the column uj or steering box. They also suspect the steering pre-loads need doing too.....
18th Apr 2013 4:22pm |
