![]() | Home > Puma (Tdci) > Rare Dual Zone Climate control option! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17715 ![]() ![]() ![]() |
Normal, I'm afraid, as are the huge fluctuations in the temperature of the air coming from the heater. Mine has two settings, "arctic" for summer use and "supernova" for the winter. If you set the knob anywhere midrange the heater will choose to alternate between these extremes.
Still, it's the nearest thing to a working heater the LR has yet come up with in Defender and is the culmination of 60 years of development. Anyone know if the Transit heater works any better? |
its a known problem and can be fixed on warranty.. they have all the dash out and put tape over part of the internal heat exchanger
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
Check your flors to see if you have any coolant coming in where it shouldn't be. i am pretty sure when I had cold hot air, the dealer changed the heater core...under warranty and I have not had any cold hot problems...but now I probably will as I have just jinxed myself. 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
Liberace Member Since: 13 Jun 2012 Location: Perugia Posts: 18 ![]() ![]() |
Thanks for the answers, bpman is there a service bulletin out (TSP #) for that repair I can show to my dealer? The attitude I get here in Italy is "don't worry, nothing you can do, it's normal for a Defender"' But if I can show them that it is a known item they will have to do it.
No coolant leaks, like I said this is the second motor, and the system was pressure checked as part of the installation ( so they say). But I have checked the level and it hasn't lost any in the 6 weeks since we picked it up. Black wolf, we may be talking about 2 different things, because I get ice cold air out of one vent and hot out of the other, but only when the vehicle is at speed. And when it's below about -5c on the highway the hot side is overwhelmed by the cold side and the whole interior gets frigid, even on full hot, but at least the driver has a warm knee! Thanks again... |
Read this thread
http://www.defender2.net/forum/topic1090.html And if you PM me your e-mail address, I will send you copy of the service bulletin. Mind, in my case the passenger side (same as for you I guess as in Italy you also drive at the right side of the street) ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
thanks Eric your filing system is quicker than mine
Actually, it was you Steve who sent it to me ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Steve, by the way........ you may be driving at the wrong side of the street now, but at least you got your steering wheel at the right side in the ICE
![]() ![]() Saw an ICE today passing in front of the office here, they are real good lookers ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Just PM'd you the fix ![]() Edit: I am surprised that this problem actually persists. Had understood that LR had changed the production and either put a different heater matrix, or added this simple fix at the production process by 2011 models already.... Apparently wishful thinking from those engineers ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks for the file erivv! I'm not very happy with the fix as described either, seems contrived....
I really dont want them to tear into my dash, but I bought this vehicle partly to drive to the Alps for ski holidays, if I can ever afford to again, so I think I,m going to need them to do it. Very strange they identified this problem 5 years ago but wont do any fix at the factory. Every other car and bike I've owned over the years that had a TSB out had a factory fix in after discovery even if it was mid-production. Seems this one is only a problem in sub zero temps at highway speeds, but doing the fix at the factory seems so easy, now LR has to pay a dealer thousands to pull a dash to put in a piece of tape!?!?! |
There are really two fundamental design problems with the Puma heater which give rise to its two characteristic "issues".
Firstly, the inlet and outlet pipes to the heater matrix are both on the left hand side of the vehicle (the heater is identical on both LHD and RHD vehicles). Due to the size and design of the heater box and the placement of the matrix, all the air which comes out of the RH footwell vent passes through the RH side of the matrix, and all the air coming out of the LH pipe passes through the LH side of the matrix. The fact that the inlet and outet coolant pipes are on the left, and the flow characteristics of the matrix, mean that the LH side of the matrix runns hotter than the RH - by the the coolant flow, if any, reaches the RH side of the matrix, it has already lost most of its heat to the LH outlet pipe airflow. The inevitable result of this is that irrespecitve of whether the vehicle is LHD or RHD, the air coming out of the left footwell vent will always be hotter than the air coming out of the right footwell vent, unless the temperature is set to full flow and then engine is producing massive amounts of heat (see below). The LR service bulletin mentioned above is intended to "solve" this issue, but all it actually does is block the air passages through the LH side of the heater matrix (where the hottest air originates) which will slightly reduce the heat emerging from the LH footwell vent. It does nothing at all to address the fundamental design problem and really is a classic bodge. Also, despite the fact that there is no difference in heater design between LHD and RHD cars, LR specifically state that the modification is for LHD vehicles only! Presumably only driver comfort is important, the passenger can go hang! The second problem arises with the inherent efficiency of modern diesel engines, and the (incredibly complex) flow characteristics of the coolant in the TDCi engine. This results in a much wider range of coolant temperatures under "normal" driving conditions - the engine produces relatively little waste heat under light loads, but a fair amount when working hard. So, after going downhill the coolant will be at a significantly lower temperature than after climbing a hill (the temperature gauge on the dash is electronically controlled and programmed to remain on "normal" over a wide range of temperatures). The result of this is that the temperature of the coolant entering the heater will vary considerably according to what the engine is doing, and this causes the output temperature to fluctuate widely, especially if the flow through the heater has been reduced (by setting the flow control valve - the hot/cold knob) to a mid-range position. The combined result of these two "features" is a heater which will never really be controllable and is not really satisfactory, and which blows air which especially in midrange setting fluctuates widely in temperature, and which produces air from the LH side vent which is generally significantly hotter than the air from the RH vent. I believe that most modern cars (at least the relatively high-end ones with some form of climate control) use a system where there is constant full coolant flow through the heater matrix, and the desired output temperature is achieved by blending cold air (which hasn't passed through the matrix) with full heat hot air (which has) by means of a thermostatically controlled flap arrangement. This will produce a more-or-less constant output temperature irrespective of engine temp and working conditions. In the case of the Defender, the "temperature" control is nothing of the sort, it is just a flow regulator of the coolant through the matrix, and there is no form of proper temerature regulation at all. As far as I know there have been no fundamental changes made to the heater since the Puma was introduced, and although is it possible that the latest ones already have the LH side of the matrix blocked off, I don't think that the MY13 heater will perfom any better than the MY07. Also, I don't hink that having aircon makes any difference to the heating issues, since the heater is fundamentally the same. There really doesn't seem to be and practical solution to this either. I have looked at thermostatically-controlled flow valves to replace the existing one, but there doesn't seem to be any readily available practical option. I have looked at fitting some kind of tubulence device of mixer in the hot side of the heater box, but there isn't room. I am sure that it would be possible to design a better heater that woudl fit, from scratch, but ultimately it doesn't really seem worth the effort. The existing one does, after all, produce more heat than earlier Defenders, and is, defective as it may be, it is still the best heater yet fitted to a Defender-type Landrover! |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
Top write up! ![]() |
Thanks! Re-reading my post I realise that I should apologise for the numerous spelling mistakes, not my finest effort!
