![]() | Home > Puma (Tdci) > injector? |
whip Member Since: 17 Sep 2010 Location: haute savoie, Alpes Posts: 18 ![]() ![]() ![]() |
I think it's an injector, but I'm not a mechanic, I have an appointment on March 13 with the garage, maybe that is the reason for the heating of the turbo and my problem of bolt and seal that break between the turbo and exhaust manifold
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I have seen this on other Ford diesel engines and its only been injector seals,the seals are only a pound or so each.Sometimes just tightening the injector can stop it. 2005 Td5 90 XS
Steve |
and it caused a bad mpg and power loss?
It will do both as you are letting compression escape from the injector seal instead of keeping it in the cylinder.Sometimes you can hear a chuffing noise under the bonnet if you have it open with the engine running. 2005 Td5 90 XS
Steve |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
Thanks for sharing the pics.
Injector seal replacement could be done easily done as DIY maintenance or some special tool or knowledge are needed ? |
It is not easy
You need new scews and gasket (copper washer). Then you must close the screw with a mix of torque and angolar procedure. See the workshop manual for details. Ohhh my fly is calling.....ciaoooo Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
