Home > Technical > Swivel Recovery Eyes or Jate rings
defenderider
Greece 2001 Defender 90 V8 Petrol HT Alpine White
Hello everyone
I have a Defender 110 and I want to buy recovery eyes or jate rings...can you please help me? From where can I buy them (online) and which one is the best?
Thank you
Wave Riding Rules BORN FREE _ LIVE FREE
Post #16016 29th Sep 2009 5:03pm
110SEB
Wherever you get them from, I would recommend strength-rated, forged jate rings (a smooth rounded one piece design) over welded 3 piece design. They're stronger.
Loads of places to find but hem don't remember where I got mine from, sorry.
Welcome to the forum
Thumbs Up
Post #16030 29th Sep 2009 7:42pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Re: Swivel Recovery Eyes or Jate rings
defenderider wrote:
Hello everyone
Thank you
Wave Riding Rules
Try www.famousfour.co.uk they have some jate rings / swivel recovery points (zinc) etc on there website, not to sure which are the best, no doubt you'll have many replies from this site, goodluck. Cogito ergo sum
Post #16034 29th Sep 2009 8:24pm
expedition
Italy 2007 Defender 110 Puma 2.4 SW Keswick Green
On this site I found many products as you seek.
And Francesco is available via email to respond to your every need.
http://www.roverworld.com/products_english.htm Vale
110 Td4 MY07 "E" Keswick Green
Post #16426 8th Oct 2009 10:05am
alantd
Paddocks sell them too (albeit the more common 3 piece version).
http://www.paddockspares.com/pp/OFF_ROAD/R...nised.html One that started out as a 2.4 TDCi 110 XS
Post #16442 8th Oct 2009 7:18pm
PaulMc
Any Land Rover main dealer will be able to supply Genuine JATE Rings - RRC3237 and the correct length and grade of M10 Bolts, Nuts & Washers.
Dingocroft - http://shop.dingocroft.co.uk/acatalog/Ropes_and_shackles.html
supply the following, mail order -
    Cheapo fabricated Sad - Ref: ZZDB1323
    Genuine, with Bolt, Nut & Washer - Ref: RRC3237KIT
    Replacement (probably Sh*tpart Crying or Very sad ), with Bolt, Nut & Washer - Ref: RRC3237DKIT
    Genuine wider (Wolf XD) JATE Ring - Ref: ZXC9435
Prices vary, according to quality Wink
Paul. Paul.
Post #16625 12th Oct 2009 7:11pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Definately go for the forged type as suggested above, although it wasn't a straightforward job to fit them to the rear of my TD5 & TDCi Defender 90's.
Basically, the fuel tank is very close to the chassis rails, and the lashing rings (where the jate ring bolts go) are fitted before the tank goes in. Meaning, that to get the bolts out you have to cut the heads off (or take the tank out if your into that sort of thing). I used forged jate rings with a thread to accept the bolt with a little less than two threads protruding, and even they were a little closer to the plastic tank than I would have prefered. Be sure to check the bolts don't touch and rub through the tank!!! Also, the LH one doesn't work too well with the fold up rear step.
Hope that's of some use.
Bosun.
Post #16626 12th Oct 2009 7:19pm
