Home > Puma (Tdci) > gearbox - how would you know |
Oh Lord ...... Time to call an ambulance for Caterham You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
22nd Feb 2013 7:23am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
22nd Feb 2013 8:36am |
Cheer up, that was probable the exception to the rule You never actually own a Defender. You merely look after it for the next generation.
22nd Feb 2013 8:42am |
blackwolf -
cheer me up why don't you its almost the weekend - you trying to spoil it for me ? |
22nd Feb 2013 10:47am |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
You can imagine a recon box might be put together with more attention to detail than the originals being churned off the factory line (like your original).
I shouldn't imagine anything else. As for second gear, I usually pull away in second to avoid the dreaded 1 - 2 change. That being said, I had other troubles with my gearbox (especially 3rd) since new (2 years ago) but a combination of changing shifting style and maybe the gearbox bedding in has made it acceptable. It'll probably last as long as the other mortal parts... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
22nd Feb 2013 12:41pm |
I'm always imagining things - some good, some bad
thanks ZeDef... |
22nd Feb 2013 1:24pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
I had a recon box from Land Rover, the gears were in the wrong way round Went like fook in reverse especially in sixth. Original Member Pie n Pea Club.
110 HCPU Tipper |
22nd Feb 2013 1:41pm |
22nd Feb 2013 1:59pm |
I've not tried low ratio yet ....... |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 |
OMG |
22nd Feb 2013 2:10pm |
