Home > Maintenance & Modifications > rear passenger door cards help reqd
farmer giles
when i was installing a pair of door stay extenders i gently prised off the door cards to be able to install a couple of bump stops and it appears that i have sh@gged up the door trim clips.
i did not remove the whole door card but the trim clips look as though they were bonded onto the door card; were being the operative word.
has anyone got experience of these fixings (fcx Matt?) and best solution to my problem.
Farmer Giles top tip - don't do maintenance or modifications on your Land Rover when you are in a very bad mood Embarassed
Post #212643 20th Feb 2013 2:29pm
Bond the bit you've ripped off back on again with Gripfill or similar Thumbs Up
Post #212649 20th Feb 2013 2:53pm
farmer giles
cheers Matt Thumbs Up
i was tempted to drill through the door card so i had an easily assessible trim clip like the older door cards
Post #212652 20th Feb 2013 2:59pm
Thud
Post #212653 20th Feb 2013 3:00pm
farmer giles
Thud
Rolling with laughter
They are Land Rovers; they are supposed to have visable fixings Very Happy
Post #212662 20th Feb 2013 3:15pm
Hot glue gun is better & quicker but not the cheapy ones
Post #212667 20th Feb 2013 3:42pm
farmer giles
just out of interest is there a special tool for removing the door cards so that the clips don't need rebonding; or is it just a slow and steady careful pry off with a screwdriver?
Post #212668 20th Feb 2013 3:43pm
There are trim pad removal tools available but they don't guarantee success - it really is a case of taking it slow.
http://www.google.co.uk/search?q=trim+pad+...p;ie=UTF-8
Ken's way is also fine, I meant some form of adhesive, not necessarily Gripfill
Post #212669 20th Feb 2013 3:59pm
farmer giles
thanks Ken and Matt Thumbs Up
Post #212671 20th Feb 2013 4:06pm
ickle
Black silicone and gaffer tape, easy to remove every 6 months to repair the central locking cables.....
Post #212838 20th Feb 2013 9:42pm
farmer giles
cheers keith,
it looks like i'm not the only person to break trim clips then Rolling with laughter
didn't realise it was you when i pulled out in winchcombe last week; your Land Rover certainly looks well planted in the rear view mirror! Thumbs Up
Post #212897 21st Feb 2013 9:08am
Happyoldgit
The clips break more easily in cold temperatures, so get the vehicle in a warm place if you can. Steve.
http://forums.lr4x4.com
Post #212930 21st Feb 2013 12:23pm
farmer giles
cheers MOG,
with my workload it may well be summer before i get round to fixing them Sad
Post #212968 21st Feb 2013 3:30pm
rs2315
Just needing help with window winder removal, as I'm taking rear passenger door card off.
Does the winder just pull off?
work off with wide bladed screw driver?
I've removed everything else, just didn't want to get aggro with the winder until I knew which technique to use.
Cheers.
rs2315.
Post #280546 8th Nov 2013 1:11pm
Press the door card by the winder handle towards the outside of the vehicle and you will nearly see a spring clip round the shaft of the winder handle.
Carefull pop the spring clip off with a suitable pointy thing and the andle will come off. Alternatively a rag passed round the winder shaft can be used to pop the clip off.
Once you've seen how it's fixed, it isn't difficult to take them off.
Post #280556 8th Nov 2013 2:15pm
