Home > Maintenance & Modifications > Is it worth rebuilding a Caliper? |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Whilst fitting my wheel spacers on the weekend, I noticed a small, tiny amount of fluid on the nearside front brake disk.
Of course, couldn't resist, had to have a taste.... Was a bit sweet, so is possibly some brake fluid (although did taste more like antifreeze, but can't be that). Anyway, I cleaned it away and so far there's no trace of more of the stuff. However, it's come from somewhere, so I'm suspecting a piston seal to go soon. So, I look at rebuild kits and they are around the £10-£15 mark, then you have to add the time to actually do the work versus just getting a nice new shiny caliper instead as looking around I've seen them between £44 and £80. I'm guessing these are not genuine replacement ones though? What's everyone's thoughts? Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
18th Feb 2013 1:34pm |
Cheers Jason,
A rebuild doesn't bother me, done plenty over the years. Just the cost and bother of it all. After getting some SS pistons and a load of seals, you are eating into a chunk of % of replacement cost of the caliper. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
18th Feb 2013 3:00pm |
This is one of the next tasks I have set myself. After replacing the calipers on the 110 shortly after buying it I kept the original calipers and plan to refurb them with stainless pistons... and why, because after 4 years the pattern parts caliper pistons are corroding badly...
18th Feb 2013 3:03pm |
That's possibly another way to do it.
Buy some 2nd hand calipers, recondition them with SS pistons, swap over, recondition the ones removed and sell them on! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
18th Feb 2013 3:05pm |
jasong4110 Member Since: 18 Oct 2009 Location: Henley On Thames Posts: 268 |
If one's going then the others could be on the way also, it really depends on how long you intend to keep the truck there are a lot off poorly made replacement parts on the market and brakes are not one of the things I would want to scrimp on and would not be fitting cheap after market parts. I have rebuilt mine with SS pistons so are happy that they will last a few years and not let me down when I need them most. Jason. |
18th Feb 2013 3:06pm |
Yeah, hence my other direction with getting some 2nd hand ones and rebuilding them. EDIT: or maybe just do the ones on there. Too many decisions. I hate making them! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
18th Feb 2013 3:07pm |
Can anyone confirm that these are the correct seal kit and Pistons. It's for a Puma XS so has the vented disks, although I don't think that will change the seals as I'm pretty sure both vented and non-vented essentially have the same caliper, but there is a spacer between the 2 halves of the vented version, so the piston bodies are the same. Won't necessarily purchase from Paddocks, just a reference.
Seal kit http://www.paddockspares.com/smn000060g-fr...l?___SID=U Pistons http://www.paddockspares.com/stc201s-front...l?___SID=U Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
18th Feb 2013 3:21pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
^^ They are correct.
As mentioned above doing the work yourself with SS/ good seals will give you the peace and mind that they will be good for the forseeable future.... rather than putting a set of 'normal' callipers on and them going bad in half the time. Exactly what I will be doing with mine Glyn |
18th Feb 2013 6:16pm |
Cheers for the confirmation Glyn! Craig Rogers
18th Feb 2013 7:55pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8026 |
in the past i have always rebuilt calipers. but lately with the cost of OME ones coming down i have just bought replacement calipers, then rebuilt and sold on the old ones for pretty much what the new calipers cost me Cheers
18th Feb 2013 8:50pm |
That was the reason for my original post. It does seem like less faff but I've bought new pistons and seals for the one side only for now. Craig Rogers
18th Feb 2013 8:56pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Are the paddock stainless pistons any good? Ive heard before that some of thecheap ones are too rough a finish compaired to the chrome on the normal ones and knacker the seals quicker?
Pete |
18th Feb 2013 9:11pm |
The Paddock ones are Bearmach. Craig Rogers
18th Feb 2013 9:16pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17378 |
When I faced the same dilemma last year I bought new Delphi calipers and then rebuilt the old ones ready for next time.
That way the Defender is VOR for a much shorter time and the rebuild isn't hurried (plenty of time to paint the calipers properly). |
19th Feb 2013 9:05am |
