![]() | Home > Technical > help |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Have you changed the fuel filter
reggielad Member Since: 30 Dec 2007 Location: staffordshire Posts: 2 ![]() ![]() ![]() |
they are aways pumping,even with engine of but igision on,shouldnt be very noisy just a buzzing sound,your lucky yours started after pump replace,changed mine and cant get it to run again
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Reg, you will probably have to programme the pump into the ecu.
Darlek, your pump should not pump all the time, should timeout after a few seconds when the ignition is turned on and the engine isnt started. Can you hear a loud hissing noise around the o/s/r wheelarch? |
