![]() | Home > Puma (Tdci) > Puma 110 2.4 Earth points |
I know there's an earth that can be seen when looking under the front drivers side wheel arch at the back that goes to the chassis.
It's worth at least installing an earth from the battery to the floor of the battery box internally as a theft prevention measure .... |
macduff Member Since: 04 Nov 2012 Location: NE Posts: 119 ![]() ![]() |
Found a schematic for post my12 defenders wiring (suspect theres some common features with mine) and it looks like theres earth points located around the loom so my hi-level brake lamp seems to share an earth with nearly every electrical item at the rear (if not all) though it doesnt say where that earth is located. so suspect front shares similar earth points (heater and headlamps etc) . though it could be joints in the loom for the converging earth leads that are faulty though I'd have hoped that wouldn't happen until a lot later in its life
![]() PS nearly had to ask what the extra earth to battery box would do.. until the penny dropped (derr - my brain is still replenishing its caffiene levels: ta for the tip) 2023 110 P400e |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 748 ![]() ![]() ![]() |
I'm going to revive this as I suspect that my MY11 D110 needs to have all the earth / ground points inspected just to be sure. Too many electric gremlins happening so asides from fitting relays to all the electrical components (to be done soon) I want to make sure that all the earth / ground points are good.
Pete4810 Member Since: 26 Dec 2013 Location: London Posts: 9 ![]() ![]() |
Hi,
on the subject of earths, Im wondering (as a newbie) where the earth cables are. I am experiencing an intermittent indicator fault. Are there any easy earths to check - before I take it to the garage - aargh.? |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 ![]() ![]() |
Take a look at this thread:
http://www.defender2.net/forum/topic48404.html Mark |
