- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
ZeDefender
Get a voltmeter on one of the sidelight (preferably headlight if you can be bothered to remove one) connectors after it's been standing for sometime. Then get someone to turn the headlights on and then start the engine, preferably out of gear
Watch how the voltage varies with the flickering - it will give you a pretty good idea what's going on. Alternatively, use Scangauge or similar if you have one. It won't be as accurate but it'll also give you a pretty good idea Tell someone you love them today because life is short.
2nd Apr 2013 11:59am |
