Home > Tdi > Immobiliser 300tdi connector PIN numbers and where they go |
pdennis30
Immobiliser 300tdi connector PIN numbers and where they go | |
Hi I have managed to get my wiring loom fitted back into the Defender today , I just need to connect up the Spider now to get me up and running again , as some of you know I cut the wiring at the connector where it goes into the unit in the battery box. Doh! I know where the wires come from in the loom , stater solenoid , ignition switch , fuel solenoid etc , I just don't know which pins they need to be connected to in the connector. I was hoping that the wiring diagram had them in the right order but that is not the case.
Does any one out there know which number on the connector the various wires go to, I know that if you by pass the immobiliser that you connect 4 pins together , where do theses come from assume 2 of them are starter solenoid and fuel cut off
Please help
Thanks
Appreciate this might be a subject that a Pm would be better instead of advertising it
22nd Jan 2013 6:07pm |
pdennis30
Please help must be someone out there
23rd Jan 2013 8:20am |
pdennis30
All sorted now
23rd Jan 2013 10:07pm |
