Home > Puma (Tdci) > Mantec RAI to snorkel conversion on puma
Page 3 of 4 <1234>
JWL
I fitted a RAI to my 110 mainly due to issues caused by my roof rack. My unusuable problem was due to my Brownchurch roof rack being covered in chequerplate and when I parked facing downhill and down slightly to the drivers side the run off of water from the roofrack, either when washing or rain, would track down the A post and front brace then track down and pour across the wing vent with some of it entering the air intake. With heavy rain or when hosing down the amount of water would far overload the drains in the system so after two air filters FUBARed I stuck the RAI on. I have plans to fix a pipe into the bottom of the RAI and have it long enough to reach the air box for no amount of silicon attempts have come anywhere near to sealing the rather tired LR pipework.
Post #299004 15th Jan 2014 11:55am
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
Whatever RAI or snorkel you fit,you must follow tatra's805 tutorial,this is what i found in my air filter box
and i have a mantec snorkel fitted by a "specialist" when previous owner prepared the Defender for the trip to Lybia..
Post #299034 15th Jan 2014 1:41pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
tatra805 wrote:
Pipe runs to the airbox which is sealed off. Pipe to inlet sealed by pumping in sealer through the “ventilator” tab holes and the vent hole. Pipe is 90mm ID, the plastic part 80 at the snorkel and the entrance of airbox 70 which can be opened up to 90mm.
I did not do this yet as you need airspeed to cool down the MAF sensor and i have no idea if the trumpet the sensor is placed in is sufficient for this, nor what limits the programmed values have and what opening up things would do with it.
Been reading this, as I want to do this mod on mine, but can't quite understand it all...Did not look under my bonet yet, but...
The pipe from the snorkel to the airbox is not one piece, with a single diameter?
You seem to have two new pipes running there? Am I looking correctly?
Shouldn't the pipe be flat on the inside?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #301483 23rd Jan 2014 1:33pm
fatman
Plenty of pics here.. http://www.defender2.net/forum/topic25864-45.html
and for more analysis read all the pages.
Keep in mind that there are differences beteween LHD and RHD defenders, heater-servo-abs are on the other side.
Post #301494 23rd Jan 2014 2:14pm
lrmaniac
I think that me, you and Tatra all drive LHD Defenders.... Thumbs Up
I've read those threads, but was having a hard time understanding some things...
Now that I've looked under my bonnet Embarassed I thing I got it...
-Tatra made a direct link from the Vent air intake to the heater (white pipe) ?
-And a direct ilink from the RAI to the air filter (black pipe)?
Just can't figure out the diameter used...70mm, 90mm....? Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #301542 23rd Jan 2014 5:36pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Lrmaniac,
you are correct
White pipe is the ventilator to top of wing
Black one is 100mm = 90mm inside diameter direct from rai inlet plates to airbox.
Airbox is opened up to 90mm also
The only restriction i have now, caused by the wall thickness of the plastic plates is 80mm
It would be better to have the black pipe made from something smooth.
But to my opinion the differences would be minimal. The best part was modding the airbox.
2cents
Smile
Post #301936 25th Jan 2014 12:34am
lrmaniac
tatra805 wrote:
[Black one is 100mm = 90mm inside diameter direct from rai inlet plates to airbox.
Just had a piece of that pipe on my hands... It's so thin, how is it 100mm on the outside and 90mm on the inside? I measured it roghly and it seemed 100mm inside & out... Question
And isn't that pipe too fragile? Couldn't it be ripped by a stone chip or when washing the engine? Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #303107 29th Jan 2014 2:36pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
tatra805 wrote:
Alex,
have you any fotos of this pipe connecting with air filter box? and a panoramic one?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  www.newfoundland.gr
Post #304671 3rd Feb 2014 12:41pm
tatra805
Hi Pouf!
unfortunately not.. (and not planning on taking the airbox out again in this weather Wink )
The hose enters the airbox housing and is glued/sealed in place. so sealant is between outside of hose and inside of airbox entrance (see pic on 2nd page where you see the white sealant that was flowing on the inside of the tube)
This is a bit opposite as normal where the hose would go over the airbox entrance and then be clamped.
Reason for doing so is that i needed to have a hose that fitted both my plastic inlet pieces (90mm OD) and the airbox 90mm ID)
hope that makes sense
Smile
Post #304674 3rd Feb 2014 12:56pm
tatra805
Hi Lrmaniac
Yes of course you are correct, the hose itself is about 1mm thick, what i meant with the 100/90 is if you would see the corrugations / spiral as full material you keep a free ID of 90 and 10mm is the spiral "thickness"
The hose that i have is heat resistant to 360°C and oil etc proof. While thin its not such an easy material to damage.
Time will tell...
Thumbs Up
Post #304678 3rd Feb 2014 1:01pm
pouf
tatra805 wrote:
Hi Pouf!
no Alex, i don't want you to take out the air box.
i want a foto like this
https://s3-eu-west-2.amazonaws.com/i.hubnu...8e4d10.jpg
but from the side of air box. just to see the hole setup.......
Post #304680 3rd Feb 2014 1:27pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I really need to do something like this, having drowned my first engine. I've seen Tatra805's mods, but unable to do the fabrication of the adapter from wing inlet to hose myself. Also recently noticed mark_d's efforts in the same department.
While browsing the usual suspects sites, I was pleased to find an adapter to allow me to do this. As I failed to buy it immediately, I can no longer find it. Has anyone else noticed this adapter being available and if so, can they please point me in the right direction.
Post #366773 23rd Oct 2014 10:14pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #366777 23rd Oct 2014 10:27pm
Inigo
That was exactly it, thank you!
Post #366787 23rd Oct 2014 10:54pm
mark_d
Inigo, I'm considering doing a group buy of the kit I've done if you are interested in the bigger pipe and powder coated finish.
See here:http://1drv.ms/1EHyGIu
edit: Broken link updated http://defender90xs.blogspot.co.uk/
Post #367062 25th Oct 2014 12:50pm
Page 3 of 4 <1234>
