Home > Puma (Tdci) > REDEX
Page 3 of 3 <123
Iktank wrote:
when I change the oil filter on my Hilux I normally fill the filler with Forte "injector cleaner" and run the engine at tick over for a few minutes until the forte has been used up, it does run nice after having such love Very Happy
I think munch90 was questioning where you are adding the cleaner - the above sounds like you are putting it in the oil filter/system? Confused
Post #394566 31st Jan 2015 8:30pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
With Landy I just put put the forte in the fuel every 4000 miles
with Hilux when ever I change the fuel filter (approx every 12000miles) I put the contents of the bottle straight into the filter, connect everything up then run the engine on tick over such that the injector cleaner is run neat thro the injectors and fuel pump, does the injectors world of good and does not harm the engine (had the Hilux from new it is now 15years old)
Sorry for posting Hilux
To correct things here's my Landy
Post #394610 31st Jan 2015 9:37pm
Page 3 of 3 <123
