Home > Puma (Tdci) > Fitting "soft" A Bar |
lornick Member Since: 02 Sep 2009 Location: Aberdeenshire Posts: 32 |
Hi Guys,
I was wodering if anyone has any fitting instructions for a genuine Defender A Bar? I've just got hold of one, but it came without any fittings - I'm looking for the correct size of bolts require to attach it to the bumper. Also interested in attaching spotlights and was wondering where I would source the brackets that run from under the bonnet to the top of the A Bar (without using the local stealer!). Thanks |
6th Sep 2009 8:18pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
They are all on the internet:
http://www.ownerinfo.landrover.com/extfree2viewlrprod/index.jsp Specifically http://www.ownerinfo.landrover.com/extfree..._Winch.pdf Mike |
6th Sep 2009 10:41pm |
Thanks for the link - makes life easier!
Landroverdiver - I'm about 20 miles west of Aberdeen, so thanks for the offer but I'll probably see if I can crack on using the links I now have. If I get really stuck I'll maybe take you up on it. Cheers, |
7th Sep 2009 7:49am |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 |
The fitting kit for said Soft A Bar can be bought seperately !
Try duckworths i got mine from there, they posted it out and it was here the next day ! DEFENDER XS CSW 08 TONGA GREEN |
7th Sep 2009 9:47am |
I think I got mine (A bar with the bullbar side bits too) from Duckworths. Fitting is easy but took it off after a while as in the end I didn't really like the look of it.
8th Sep 2009 3:43pm |
Mine came from a dealer down south - although the winch version, it was a pig to fit..im not so sure something wasnt right (could be anything up to and including the car ) - but in the end its on Mike
8th Sep 2009 4:32pm |
