Home > Maintenance & Modifications > Dual battery installation - critique my wiring diagram!
mikeh501
Hi all,
1st post Very Happy been lurking for a while and on other forums. My batt recently died on my 90 which spurred me on to sort out a dual battery installation. Ive now bought the 2 batteries and have started to plan out what electrics i want on the vehicle and how i want the wiring arranged. So i thought id put together a wiring diagram which i can then show a proper auto-electrician and get a quote for the work. given i know a number of people have put dual batteries into their defenders then im asking what you think of my wiring diagram! whether its any good or complete cobblers!
EXT AND = External anderson connector for jump leads
VSR = Bluesea automatic sensing relay for battery charge/discharge
4-POS BUS BAR = Those metal bars with 4 posts which you can use to tidy your electrics
12-DIST FUSED = A 12 way fuse box for connecting ancilliraries
Electrical Setup by mikeh501, on Flickr
No fuse on winch? just an isolator, as i read that winches draw a variable current which means id have to put a very very big fuse in place defeating the object?
Chassis earth back to bus bar not battery? thoughts...
Post #199929 8th Jan 2013 1:35pm
I'm looking at this on my iPhone do not had a good look but I would say its still worth putting a large mega fuse on each positive as it will blow if there is a dead short, in the event of a collision for example.
I've used the bus bar arrangement for my earths too, worth adding an additional earth within the battery box as a security precautions
Also the top diagram differs from the bottom, have you mislabelled the batteries in one of them ?
Post #199933 8th Jan 2013 1:43pm
mikeh501
ill add the megafuses to each positive battery terminal.
not sure what you mean by adding an additional earth within the battery compartment. You mean literally putting a wire from the bus bar to the metal of the battery box?
the two diagrams should be the same, but yes there are a few bits labelled inconsitently. Still2 batteries however (START and ANCIL/LARY) The anderson connector in the bottom is the "EXT AND" in the top. VSR is the same as ACR etc.
Post #199969 8th Jan 2013 4:10pm
leeds
A few comments for you Mike.
Depending on battery sizes and vehicle you may need to level off the bottom.
Depending on size of batteries positive terminal might be getting close to box lid. Rubber cover over positive terminals plus insulate bottom of lid.
Why 2 12 way fuse boxes? That is 24 extra circuits rather a large number I would have thought!. Check on phyiscal size of fuse boxes if putting them in main battery box
Why use a 4 post bus bar? A stud terminal connector can take 4 35mm2 cables
Is your auxiliary battery a starter/leisure battery? Winches draw high currents whereas radio etc is low.
Is your ACR a linkable one? Useful if main battery goes down or doing lots of winching.
Your fuse boxes have a 100 amp fuse in line plus a relay isolator???
Brendan
Post #200380 9th Jan 2013 8:56pm
Luismi
Spain 2004 Defender 110 Td5 SW Alpine White
Nice schematic, however find a sensing relay, your ACR/VSR, that you can manually operate too.
My schematic differ of yours just a bit , mine has a battery selector 1-2-both-off in negative rather than your bus bar.
This two things will give me some options , like i can start the engine with battery 1 or 2 or i can disconnect all and do some welding in the car.
Hope this helps
Post #210013 9th Feb 2013 10:52pm
mikeh501
ive slimmed it down to one at the mo. i was thinking of balancing the load across 2 fuse boxes, but it is total overkill tbh.... nothing wrong with that lol
Didnt know that, ill go have a look.
ive bought 2 Numax CXV-X 1000 which are both leisure and starting as i understand it. Ive measured up and they should fit in the battery tray Whistle
I was thinking of one of those bluesea 120a ACR. its the one which doesnt have the remote button. Just wasnt sure if the more expensive one was complete overkill! Shocked
I wanted a way of isolating all the ancillary equipment in one go, so an isolator for the fuse boxes and one for the winch. you think this is bad? i still need a fuse even if i have an isolator right?
Post #210073 10th Feb 2013 9:16am
mikeh501
Hope this helps
Thanks Very Happy
I think your talking about the more expensive bluesea ACR which brendan mentioned also. im not sure if its more than i need. we will see.
re: the battery isolator, im not sure how would work. so on the nagtive side you wire my earths into a switch which allows me to isolate either battery, or knock out all the earths thereby turning off the vehicle? is that correct? will the switch have enough amperage to handle all the loads? i was worried a 350a bus bar wouldnt be enough to handle the peak loads from the winch and ACR in certain scenarios.... am i worrying about somethign which wont happen Rolling with laughter
Post #210075 10th Feb 2013 9:22am
leeds
An isolator for the winch is a good idea. Am not sure I would put a fuse inline. Remember at full load winch could be pulling up to 500 amps. Double lining halves the load and speed though. Having a blown fuse when winching????
I can see the logic of isolating all the auxiliaries however I would not do it. Not a bad idea in itself, just different people have different ideas/ways of doing things.
Get different ideas and then decide what is best to suit your needs.
Brendan
Post #210086 10th Feb 2013 9:59am
VeeTee
Netherlands
Is the VSR capable of handling (very) high currents? Because the winch is draws its current from the ancillary battery, there will be leveling between the ancillary and starter battery during winching.
I would rather connect the winch to the starter battery, so when the winch is used and the engine is on, the alternator can deliver some of the current needed directly to the winch without need to go through the VSR. Cheers, Vincent
MySite
Post #210121 10th Feb 2013 11:46am
mikeh501
Hmmm I don't it. Was looking at this one which is 120a continuous.
http://www.mobilecentre.co.uk/index.php?ma...cts_id=245
They do a bigger one which is 500a.
Just a thought but if the winch is taking load from the ancillary battery surely the vsr will disconnect the two batts?
Is it the norm to connect the winch to the starter batt rather than ancillary battery?
Post #210141 10th Feb 2013 12:54pm
Luismi
[quote="mikeh501
Thanks Very Happy
re: the battery isolator, im not sure how would work. so on the nagtive side you wire my earths into a switch which allows me to isolate either battery, or knock out all the earths thereby turning off the vehicle? is that correct? will the switch have enough amperage to handle all the loads? i was worried a 350a bus bar wouldnt be enough to handle the peak loads from the winch and ACR in certain scenarios.... am i worrying about somethign which wont happen Rolling with laughter[/quote]
Hi Mikeh
I always speak about the most expensive stuff on this matters Wink always i money well spend, i cant think of my car on flames because i save some money, for certain i will go for at leat 400 Amp continous rating.
Yes the negative switch will stop all the electrical if you want. if you decide to go for that you can use the 500 Amp switch as the blue sea PN3002 Hd series or similar.
About the current capacity just as an example land rover install 25 mm2 cable to feed the winch, when i will go for a 95 mm2,
Leeds is right this have to work for you, in my case i do it that way because i want fully control my electrical instalation, i have two warnings already and i work on a related sector.
120 Amp is clearly not enough if you are running the winch i use 120 amp relay just for the compressor and a continuos 400 Amp relay that work alone to do the charging and protect battery 1 of discharge.
Initially i plan to install a battery isolator however as i have an inverter/charguer installed i have to discard that option.
My 400 amp "smart relay" put in parallel at demand the two batteries for winching to split the "pain" if that makes sense.
HTH
Post #210190 10th Feb 2013 4:20pm
mikeh501
Luismi wrote:
Hi Mikeh
HTH
thanks for all the feedback guys, its invaluable.
the reason for the 120a bluesea ACR was that id read that the amps between batteries (at least those in a state of normal charge) is fairly nominal, so assumed nothing like 120a would be flowing between them, except on occasion.
what i cant get my head around...
if you have a winch pulling 400a load from the ancillary battery, how much of that load is being pulled through the ACR from the starter battery? surely the path of least resistance is to the ancillary battery and not through the ACR.... confused.com
Post #210226 10th Feb 2013 5:51pm
VeeTee
Netherlands
Some interesting reading here... Cheers, Vincent
MySite
Post #210262 10th Feb 2013 7:51pm
Luismi
You will have the alternator and the starter battery in the other side of the ASR then, based on your diagram and the setup of your ASR, you will work with all (alternator, batt1 and batt2) in parallel in that case.
Then you will need to consider alternator and Starter battery current going through the relay.
Depending of the status of your batteries..., but thinking in a good battery, after you start the engine the alternator will send to the battery arround 60 Amp for 10 to15 seconds , after that normally you can read 3 to 5 amp going to the battery and alternator take the rest( consupmsion, lke radio ligths o on) this means that your ASR in arround 30 sec after start will conmute to close and put in parallel the second battery.
Please keep in mind that depend of the status of your batteries and the current setup of your ASR
Post #210402 11th Feb 2013 2:09pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
As you've bought two identical batteries, why not just wire them in parallel. Then wire winch + and - directly to batteries via isolator.
Keeps everything simple and no chance of limiting power to winch.
Steve
Post #210418 11th Feb 2013 2:39pm
