Home > Maintenance & Modifications > X Engineering disc hand brake - worth the trouble & expe
BigWheels
I was thinking of having one of the disk handbrakes fitted to my Puma. Are they worth the money for kit & labour?
How easy is tightening up compared to the OE drum? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #195757 22nd Dec 2012 6:35pm
Worthwhile, easy fit... Old ones rattled. Not sure if that's been fixed Question
Post #195759 22nd Dec 2012 6:36pm
leeds
Simple answer?
YES YES YES
Must admit I like the X Eng gear. Simon is passionate about the gear he makes. In general term he comes up with good innovative ideas Thumbs Up
We have used his X brakes on our vehicles and they are good.
Must admit I do need to get around to fitting them to our latest addition.
There was a minor problem with the pads rattling on his early models. A spot of silicone sorted the rattle out.
Would I recommend them? YES
Brendan
Post #195772 22nd Dec 2012 6:57pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Another yes here Smile
Mine too rattled though, very badly. Even the silastic trick on the rear of the pads did not cure it. I phoned up x-eng and they talked to me about what might be the problem.
I think the o-rings on the sliding pin and the pin clearance were not tight enough. I stripped them out and silastic the pin into the caliper. Not a rattle since. Bear in mind this part is the caliper and not the x-eng designed part, if it persisted they were only too happy for me to return it. But the silastic cured it.
The hand brake now feels very strong, a standard handbrake is good but it's Achilles heel is it collects a lot of stuff in the drum which contaminates it ( oil, mud etc. )
Some of their defend range next I think.
Steve
Post #195781 22nd Dec 2012 7:17pm
ZeDefender
Was in my secret hiding place recovering wife's Christmas presents today, when I came across my X-Brake again waiting to be fitted when the warranty expires. Only 14 months to go...
I discussed handbrake problems at length with Simon before I bought mine and I was incredibly impressed by his knowledge and helpfulness (about several other Defender problems too). The instructions I have with my X-Brake already mention the silicon fix which I will use before I fit it - hopefully that will sort it Thumbs Up Tell someone you love them today because life is short.
Post #195792 22nd Dec 2012 8:05pm
jst
i like X - brakes but to be honest the std drum hand brake on my puma works well, but then it doesn't do alot of off road stuff so doesn't suffer from FOD.
however the other 3 LRs which get more use on all sorts of terrain all run X-Brakes and none of them rattle. simple to fit and adjust and they work perfectly. Very reliable. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #195794 22nd Dec 2012 8:09pm
GUM97
As others have said, YES Very Happy An absolutely fantastic product which cures (one of) the Defenders Achillies heels Thumbs Up An engine to TDi for!
Post #195795 22nd Dec 2012 8:09pm
Mo Murphy
Another yes here, first class kit !
50 Shades of Pennine Grey
Post #195914 23rd Dec 2012 12:10am
Dangerous
And yet another yes
Very easy to fit and adjust. Can now park on the steepest hills nowing it will stay there
Post #195916 23rd Dec 2012 6:45am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Definitely not worth the money or the effort of fitting it!
Only joking Laughing One of the best mods you can make to your truck!
Mark Thumbs Up
Post #195920 23rd Dec 2012 8:03am
BigWheels
THanks guys. Will add to my 2013 mod list. Cool Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #195947 23rd Dec 2012 10:18am
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
You can't go wrong with X-Eng kit. It's all good with some being b....y fantastic.
Simon is very passionate about everything he sells and rightly so.
X-Brake is excellent and I am now not worried about parking on hills.
Try out his suspension kit too. The X-DeFlex is excellent especially when you have the X-Springs as well Thumbs Up Thumbs Up Thumbs Up .
As for the X-Anchor, couldn't be without it. Thanks Simon Bow down Bow down
And NO, I do not work for them.
Post #204982 24th Jan 2013 3:22pm
Dieselhead
How mutch do these cost then?
Any pics of this set up Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #206395 28th Jan 2013 9:19pm
GUM97
Some info here
http://www.x-eng.co.uk/X-BrakeDef.asp
Post #206548 29th Jan 2013 5:01pm
