Home > Puma (Tdci) > Puma Clutch
LROV90
Australia
Puma Clutch
Hi,
Is there a LR service bulletin out for the clutch rattle that some people seem to be having their clutch replaced for?
From what I understand the symptoms are a rattle when the engine is started / turned off with the clutch pedal out?
Thanks
Post #14552 24th Aug 2009 10:49am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I'm pretty sure there is. I just had mine replaced the other week but the noise was as you described and also when depressing the clutch. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #14561 24th Aug 2009 12:47pm
Eduardo
LROV90
Yep, this is a common failure (mine also had it) and there is a bulletin about it.
Please see this old thread were the bulletin is.
http://www.defender2.net/forum/topic933.html
Is quite vague in the simptoms but is better than nothing.
Cheers Eduardo
Post #14564 24th Aug 2009 2:32pm
