Home > Wheels & Tyres > 265/75/16 tyre opinions?
Page 1 of 3 123>
Gareth
My 90 CSW with Boost alloys needs 4 new tyres. It has got the original 235/85/16 tyres still on it, they are now 10 years old and starting to crack on the sidewalls.
I was wondering if there is any benefit apart from looks to fitting the larger 265 tyre? The spare on my 90 is a brand new 235/85/16. If I were to fit 4 new 265's but keep the 235 as the spare would that be illegal? Is there any law that states that the spare has to be the same as the roadwheels? I think maybe not, because loads of cars have space savers.
The car is only used mainly for road duties, with a bit of caravan towing and easy green lanes.
Anyone got any pictures of their Landy with 265's on? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #194123 16th Dec 2012 9:10pm
Lorryman100
265/75x16 Mickey Thompson Baja MTZ's on standard boosts Thumbs Up
Post #194128 16th Dec 2012 9:26pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
You wouldn't pass an MOT with dissimilar tyres but many cars a supplied with a space saver so should be OK.
I have never used my spare, it's now 12 years old.
This is mine with 265 just before I replaced them just because they were old and looking a bit tired.
Post #194129 16th Dec 2012 9:28pm
Green Machine
Have a look here for what various combinations look like. A quick search for 'tyres' will throw up a whole stack of threads for you to have a look at - its a very often discussed topic! Personally I run BF Goodrich all-terrains in 265/75/16 as do many, many others. I think your spare does have to be the same size as your other tyres, although I'm not certain about that. Mine is anyway, but only for the reason that I wanted a full matching set of 5. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #194130 16th Dec 2012 9:28pm
Retroanaconda
265/75/R16 was a standard fit size for some blingy models, so you won't have any issues.
Personally I prefer 7.50R16 or 235/85/R16. At the end of the day it will make little difference, so go with your preference.
Post #194140 16th Dec 2012 9:44pm
Re: 265/75/16 tyre opinions?
Personally, I would change all five if I were going to change sizes. Not because it's illegal - more because it's just 'wrong'. One of my first purchases for my 110 was a matching spare as the PO was a cheapskate and only bought 4 x 265's.
Mine are General Grabber AT2's fitted to standard Boosts but on 30mm spacers. The tread is just under the arches but the steering lock is superb:
 Darren
Post #194165 16th Dec 2012 10:24pm
For at least the last 6 years my Disco II has passed every MOT with 265/75x16 BFG Mud T/As on the road wheels and a 245/75x16 Mud T/A as a spare. No tester has ever even looked under the spare wheel cover, and I am not even sure that they're allowed to.
Having said that it would probably be illegal for me actually to use the spare I the event of a flat, but fortunately that has never been put to the test!
Post #194177 16th Dec 2012 10:37pm
No, I don't believe they are. It's not an MoT requirement to even have a spare wheel, IIRC, although if it's easily accessible then they will check it. Darren
Post #194178 16th Dec 2012 10:40pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
I run 265/75s on my 90.
235/85 and 265/75 are almost the same diameter, so if had to run you 235/85 as a spare in an emergency you would be reasonably OK - though obviously not for long periods...
Not sure if the pic will help as I'm running a 2" lift with HD springs (for overlanding load weights) so there is a lot of space between the tyre and wheel arch when unloaded.
 Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #194203 17th Dec 2012 1:05am
leeds
How much is a tyre?
£100-150?
How much is your life worth? The life of your family? How much is the life of a stranger worth?
Those 4 round rubber things are all that keeps your vehicle in contact with the ground!
Rubber degrades due to several mechanisms including ageing, oxidisation, exposure to UV, exposure to salt etc etc.
There is I believe an industry standard which says tyres should not be sold if they are 5 or 6 years old.
We have just replaced tyres less then 10 years old because they were showing signs of ageing. Cracks on side wall, cracks between the tread blocks. Plenty of tread left and passed MOT.
Our life's are worth more then a few quids of rubber.
In my opinion change all five tyres, same size, same manufacturer, same tread pattern.
Brendan
Post #194208 17th Dec 2012 1:53am
265-75-16 BFG KM2's
G I'd run BFG KO's or Cooper ST's Thumbs Up
Post #194211 17th Dec 2012 7:22am
Gareth
Thanks for all the pictures and opinions. Thumbs Up I know lives depend on tyres, that's why I am changing them, I just wanted to know what the 265 fitted like, as I do feel the 235's look a little weedy.
The reason I ask about keeping the spare is that it is brand new, and not a 10 year old tyre, its never seen the road yet. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #194239 17th Dec 2012 10:23am
alfajock
United Kingdom 1989 Defender 110 V8 Petrol CSW Bonatti Grey
265 BFG MTs on 7inch Modulars + 30mm spacers. Just legal Smile
 Fully Restored 89 110 CSW V8
CLS 350 CDI for the sensible stuff
Post #194325 17th Dec 2012 5:11pm
Martin
Site Admin
G, I run 265/75 on my 90
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #194330 17th Dec 2012 5:22pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Here's some shots of both sizes on the same vehicle.
235 85 16
Post #194346 17th Dec 2012 6:12pm
Page 1 of 3 123>
