Home > Td5 > Headlight panel
mk1collector
Headlight panel
Can anyone give me the part number for the n/s headlamp panel for a 53 reg 110? I've tried to find one but they don't seem to come with the headlight mounting welded to the back but I'd like a complete one if poss. Or can anyone recommend a breakers yard that might have a good condition one in please.
Ray Thumbs Up
Post #193066 12th Dec 2012 11:05pm
It comes as two parts... the front "panel" bit, and then the headlight mounting bit that is either spot welded, or riveted to the back of it.
front panel, N/S for Td5 is ASW710150 and the headlight mounting is ASW710130
Post #193089 13th Dec 2012 7:44am
mk1collector
So you can't get it complete anywhere?
Post #193103 13th Dec 2012 9:26am
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
if you spot weld drill bit to drill out the welds and drill out the pop rivets headlamp panel can be removed and reused having had to completely remove and repair O/S wing on my defender 90 last 3 week it finely back up and running Very Happy
Post #193122 13th Dec 2012 12:13pm
