Home > Td5 > Dipped lights dim!?
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Dipped lights dim!?
Hi guys
My td5 dcpu my04 is behaving badly Evil or Very Mad
The flasher isnt working, dipped headlights are dim and i mean candlelight dim, the dashboard lights keep blowing out and the side lights keep blowing.
Ive also got rough running problems. Running on less cylinders etc. maf sensor unplugged made a difference but drank fuel like no tomorrow so cleaned and replugged. Turbo sqeals occasionally, have got a new one to replace.
Any ideas?
Cheers wil
Post #190543 3rd Dec 2012 10:57am
Tiger
Bad earth?
Post #190563 3rd Dec 2012 1:12pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
For the engine running faults, have you checked at the ecu under the drivers seat? Known fault is oil running down the wiring loom from the engine and contaminating the ecu.
Post #191228 5th Dec 2012 6:32pm
willyj
Yup, checked the ecu, no oil, i clean it now and again and have changed harness. I keep getting side lights going and towing electrics play around. One thing is, the flash doesnt work and i was wondering if that could be something? Ill have to take the dash out and have a look me thinks.
Wil
Post #192916 12th Dec 2012 10:08am
ickle
Try extra earths with jump leads, battery to bulkhead, battery to earth point under seat box etc, if it improves things either clean up existing earths or add new ones in inaccessible.
Keith
Post #192965 12th Dec 2012 4:45pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Check the wiring that runs through the wings, when i say check i mean unplug from head lights, horn, side lights etc and pull the loom through. You may well find that the loom has chaffed through, this is getting more and more common on older TD5s 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #193311 13th Dec 2012 9:47pm
