![]() | Home > Tdi > 200tdi 90 h reg |
Well if it suits your needs, and you can afford it, and you want it, then buy it. It seems a decent price, but the gearbox would probably need repair by a specialist, not really a DIY job, An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1849 ![]() ![]() ![]() |
Would be worth doing a search, I can remember something about the indent springs and bearings messing up but being repairable in heh car on a LT77 box.
Also they run ATF, yes ATF in the gearbox not gear oil, this can lead to non changing gears. Box was same / same family as the TR7, jaguar etc. Regards Keith |
boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48 ![]() ![]() ![]() |
cheers guys, think i will give this one a miss but thanks for the advice
