Home > Wheels & Tyres > Which wheel carrier should i buy?
Page 2 of 3 <123>
VeeTee
Netherlands
Zinke wrote:
Has anybody got any pics of a standard safari equip one fitted? I dont like where the pivots are bolted on the one in lrmike's picture, but that has a jack mount on it. Are the standard ones mounted in the same place as the Mantec ones or are they still on the side like lrmike's?
Pete.
I have the same setup as lrmike's:
 Cheers, Vincent
MySite
Post #189933 30th Nov 2012 10:18pm
BigWheels
kmac wrote:
Actually a factor for me was - do you need to drill into the body work to install?
There are some that just fix to the corss member and don't require drilling into the bodywork
e.g. Nakatanenga, Safari Quip do one, there are others that I can't recall just now.
Fair premium on these though compared to the bodywork mounted ones
I would definitely go for one where no drilling to the bodywork is required. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #192162 9th Dec 2012 10:08pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I have the Safari Equip version, with the jack mount, but after a few years the powder coating has just flaked off.
I also didn't like the rubber bumper/door stop used in the mechanism to stop it vibrating, seemed a little "micky mouse" to me.
So, I've taken it off and reverted back to a standard carrier. I'll probably ebay it soon, as its just taking space in the shed.
The Mantec one, from what I've seen, have a better anti-vibration mechanism, but haven't seen one with a jack mount.
cheers
simon
Post #192174 9th Dec 2012 10:29pm
leeds
If you do not want to drill the body work you have in the UK three choices to the best of my knowledge.
1) Safari Equip single pivot wheel carrier
2) Nakatanenga single pivot wheel carrier
3) Alisport single pivot wheel carrier
1) and 2) are about £400-425 whereas 3) is about £800
Brendan
Post #192175 9th Dec 2012 10:32pm
Lorryman100
The Nakatanenga wheel carrier gets my vote for simplicity of fitting and looks,
The wheel on the carrier is a 305/70x16 and its the crossmember that takes this weight.
Brian
Post #192178 9th Dec 2012 10:45pm
AndyS
I don't understand the point of rear wheel carriers, it seems it's £200 to save a £5 hinge. Am I missing the point?
Post #192180 9th Dec 2012 10:50pm
BigWheels
Brendan
Ouch! Wouldn't rear door bracing be cheaper. Such prices press DIY buttons for me. Its only scaffolding.
Same ripoff as roll cage prices. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #192181 9th Dec 2012 10:51pm
leeds
NO comment!
Brendan
Post #192184 9th Dec 2012 11:02pm
davew
It's not just the hinge, it's the whole door it can save. It's probably more of a "more crap to bolt to my Land Rover" for most but if you're intending traversing rough tracks, especially at any speed, the standard door frame and hinges aren't up to the job for any sustained period.
There's a lot of weight in a spare wheel and it's normally suspended by a thin steel framed door with an aluminium skin. The later style single piece door is a LOT better at this than the earlier two part one but on rough tracks the door takes quite a pounding.
Some of the wheel carriers have a lot of movement in them when the door is closed though which suggests they probably don't help much... http://www.yorkshireoffroadclub.net/
Post #192198 9th Dec 2012 11:22pm
AndyS
Horses for courses then, that's fair enough. But I'll still put it on my 'not needed' list.
Post #192226 10th Dec 2012 1:15am
pannawonica
Australia
I have a Kaymar wheel carrier, without it I have no doubt that the rear door would have major issues due to corregations. However if you only do the Chelsea tractor thing (Nothing wrong with that.) then theres a point in not spending the dollars. Laughing
Post #192228 10th Dec 2012 5:02am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Famous last words........
I've seen rear windows "explode" in three or four Defenders allready.
Once the door is bent there is absolutely nothing you can do but buy a new door. Usualy the bend can't even be seen and the only symptom is the constant exploding rear window......and replacinig the window won't help....it will just explode again.
Believe me......£200-£300 is small change compared to a new door and window.
See it as insurance!
Post #192229 10th Dec 2012 5:42am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Thanks for all the replys. I have ordered a Mantec one this morning, my parts guy said he could get a good deal on one and he did so it was ordered.
Many thanks.
Pete.
Post #192336 10th Dec 2012 4:19pm
davew
Having compared all the available carriers during the summer, we decided on the Mantec one, really must get around to ordering it ! http://www.yorkshireoffroadclub.net/
Post #192408 10th Dec 2012 7:17pm
Some of us don't have rear doors - we have tailgates!
If you have a tailgate then IMHO there is nothing to beat the Sonic/Alisport carrier. It is not ideal if you have a door, though.
Post #192437 10th Dec 2012 8:10pm
Page 2 of 3 <123>
