Home > Maintenance & Modifications > Which switch please?
kateb
We are thinking of fitting a work light to our defender but the switch to fit our 06 td5 is pretty expensive from the dealership, can anybody recommend a direct alternative that fits as well into the standard facia please?
Thanks all
Kate
Post #188562 26th Nov 2012 5:32pm
Carling? Or are you wanting to keep the factory only look?
Steve $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #188576 26th Nov 2012 6:32pm
leeds
Do a search on PaulMc post such as this one
Brendan
Post #188629 26th Nov 2012 8:34pm
JWL
Might be an idea, I fitted a couple of switches into a couple of the "blanks" on the console. I took a blank into my local Maplins, looked at their selection of switches and found a small rocker switch that would fit within the blank after I cut a hole out and used that to trigger a relay that powered the gadget. One controls the master switch for my heated screen the other controls my marshalling lights. Even though I won't be getting rid of my 110 in the future, a blank to replace the switch is a damn site easier and cheaper to replace back to standard than a hole in the dashboard.
Post #188640 26th Nov 2012 9:00pm
mobilecentre
http://www.ebay.co.uk/itm/Mini-round-rocke...483724f62c
15mm hole required!
Genuine LR switch for aux lights is about £50 with VAT!
Post #188645 26th Nov 2012 9:11pm
