Home > Wheels & Tyres > Wheel carrier and bumperette combi
Page 2 of 2 <12
JMG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Stornoway Grey
How's this then
I want bumperettes, a swing away wheel carrier and a ladder to reach my roof rack, is this combination possible
Ta. JMG
Post #394294 31st Jan 2015 7:17am
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
leeds wrote:
There can always be issues when people buy aftermarket kit from different manufacturers in are they compatible with each other.
Nakatanenga are planning on doing rear bumperettes to work with their wheel carrier.
That would be a great combination I reckon, especially if they made 90-specific bumperettes to allow for the mudflaps.
Post #394316 31st Jan 2015 9:48am
K9F
JMG if you do a search on Google Images for 'Defender Rear Ladder' there are several short ladders depicted fixed to the nearside rear quarter that would not impinge on the swing away or bumperette at all.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #394318 31st Jan 2015 9:51am
leeds
Hardcharger, if you need any help with Safari Equip give me a shout as we supply their gear and are very close to the factory.
JMG, with a 90 you have a large choice of wheel carriers. The Patriot roof rack ladder bolts above most rear bumperettes onto the two rear cross member to body tub bolts. So ladder is not an issue..
HTH
Brendan
Post #394602 31st Jan 2015 10:23pm
HardCharger
Thanks leeds!
Will definitely ring you up when the time comes. Do you ship overseas?
Post #397315 9th Feb 2015 3:29pm
leeds
Hi HC we have sent wheel carriers to Australia, Zambia, Philippines etc.
If it goes outside the EU then we deduct UK VAT of 20% from the goods. Web shop does not do carriage automatically for foreign destinations, so will need delivery address to work out carriage costs.
Brendan
Post #397412 9th Feb 2015 8:35pm
HardCharger
Thanks leeds! Will work out what I need and get the coin.
Post #397591 10th Feb 2015 12:09pm
MartinK
Here's my modded Safari Equip bumpeerette:
The inner support has been shortened by 5mm, so that it meets the Naka Stainless Wheel Carrier (which has a 5mm plate at this point.
The inner part of the inner bracket has been removed.
It still looks mighty strong.
£30 IIRC at my local blacksmiths... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #401423 23rd Feb 2015 4:57pm
nitram17
Is it not possible to add a 5mm spacer piece (to match)to the outer side attachment ...I know it would make the off side bumper 5mm further out than the nearside but it would save you some dosh and most people would not notice!
Post #404605 4th Mar 2015 11:17pm
MartinK
I did think of that, but you would still need to cut-off the innerside of the innermost bracket (with my combi anyways)... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #404914 6th Mar 2015 9:44am
Pickles
Would the Safari Bumperettes fit when the vehicle has LandRover chequer plate on the rear corners?
Pickles.
Post #405186 6th Mar 2015 10:38pm
nitram17
Yes!
Post #405189 6th Mar 2015 10:56pm
Page 2 of 2 <12
