Home > Tdi > Water ingress cure???
peterl
1987 Defender 90 300 Tdi HT Epsom Green
The rubber strip between the hard top and rear tub is letting in water just behind the o/s door. I know you can get replacement rubber seals, but is the use of silicone or similar a better option, and if so, what do you recommend?
Pete
Post #181497 2nd Nov 2012 9:28pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Im sure i've seen posts on here where masking tape is placed either side of the seal, run a bead of sikaflex and then smooth out by running a finger down it.
I'll try and find it.
Post #181564 3rd Nov 2012 8:04am
Phoenix90
Found it here
Post #181569 3rd Nov 2012 8:10am
Phoenix90
Found it here
Post #181570 3rd Nov 2012 8:10am
peterl
Thanks for this, will get the job done when the weather clears up
Post #181852 4th Nov 2012 7:11am
WarPig
What colour did you use? Clear?
Post #182172 4th Nov 2012 10:09pm
Martin 01
Your better off using roof & gutter sealant. It remains more flexible.
Used it on mine.
Can be used in wet conditions
Martin
Thumbs Up
Post #193313 13th Dec 2012 9:50pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
It's a foam strip, so after a while it compresses and doesn't seal as well. A good new seal fitted ok with stay watertight for at least 5 years, but as has been suggested you can make sure by adding some sealant too.
Post #193322 13th Dec 2012 10:21pm
