Home > Camping, Caravanning and Holidays > Water storage - shelf life
excossack
I have as part of my kit for car rallies, a white, semi transparent 5 litre water container which surprisingly contains tap water - just in case.
This normally sits in the back of the landy.
How long does water keep fresh stored like this? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #181470 2nd Nov 2012 8:30pm
leeds
Quote:
The U.S. Food and Drug Administration, which regulates the quality and safety of bottled water, has neither set nor suggested any limitation to the shelf life of bottled water.You may notice that most bottled water containers sold at retail bear a two-year expiration date. This acts as a lot number and is for stock rotation purposes. It does not mean the product is substandard after that date. Thus, bottled water purchased in bulk is good indefinitely if stored appropriately. Appropriately means unopened in a cool, dry place away from odors and toxic substances.For those yearning for a more technical explanation, it is thus: Bottled water is considered to be of virtually no significant nutritional value. Therefore, unlike milk, fish or poultry, bottled water is not an adequate substrate for pathogens responsible for the majority of food-borne illnesses. In that regard, IBWA's general position is that as long as bottled water is packaged in accordance with FDA processing and good manufacturing practices, 21 CFR, Part 129, and meets the FDA quality standard provisions as outlined in 21 CFR, Part 165, the product's shelf life should remain intact for an indefinite period provided that product storage and other post-packaging and handling practices do not adulterate or deleteriously affect the finished product. Whew!
quote]
Use the following guidelines when storing water:
1. Store drinking water in carefully cleaned, non-corrosive, tightly covered containers.
2. Store containers in a cool dark place. DO NOT store in direct sunlight. Polyethylene plastics (prepackaged milk and water bottles) are somewhat permeable to hydrocarbon vapors. Keep away from stored gasoline, kerosene, pesticides, or similar substances.
3. Stored tap water should be rotated every 6 months.
Prepackaged bottled water should be rotated once a year. Check the pull date on the container. Be sure it didn’t sit on the store’s shelf for a year before you purchased it. Self Serve Bottled Water should be rotated once a year, as long as the water treatment process includes ozonation.
4. Rotate your stored water with the water you use on a regular basis. This practice helps insure you don’t have water stored longer than one year.
Containers That Can be Used for Water Storage
Food-grade plastic or glass containers are suitable for storing water. One-, three- and five-gallon water containers can be purchased from most outdoor or hardware stores. Any plastic or glass container that previously held food or beverages such as 2-liter soda bottles or water, juice, punch or milk jugs, also may be used. Stainless steel can be used to store water which has not been or will not be treated with chlorine; chlorine is corrosive to most metals.
[/quote]
3. Stored tap water should be rotated every 6 months. Prepackaged bottled water should be rotated once a year. Check the pull date on the container. Be sure it didn’t sit on the store’s shelf for a year before you purchased it. Self Serve Bottled Water should be rotated once a year, as long as the water treatment process includes ozonation.
rendan
Post #181492 2nd Nov 2012 9:14pm
walfy
If you are that concerned about life of water in your containers then why not empty out after every trip you do? Unless you are going around the world in 1 hit you should be rotating your water containers on a regular basis.
If you have store water for long periods of time why not purchase a kit that will tell you what your FRC is? Lovibond are a company that provide this sort of equipment, they did at 1 point supply the Army with kit to compliment the water purifacation sets we used.
As a Royal Engineer, I have provided potable water to Battlegroup sized formations in some very hostile locations. At the end of the day we still came down to the Lovibond kit to prove that we had the corect FRC in the water we supplied to the troops 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #181615 3rd Nov 2012 10:26am
leeds
FRC =???
Brendan
Post #181624 3rd Nov 2012 10:49am
walfy
Sorry for going all technical.
FRC = Free Residual Chlorine.
We worked on 5ppm (parts per million) of FRC. But this will leave a slight chlorine taste to the water. Once we issued the water with 5ppm we then issued detaster tablets which then removed the taste. The adding of detaster tablets was the end users responsibility not the RE who provided the water.
The longer we stored water the FRC would diminish as the bacteria in the water grew the FRC reduced to combat this. Hence we always tested water before issue and individual units would then momitor the FRC in any water they have stored. But in general units would only hold enough potable water for their immediate needs. They wouldn't store water for weeks on end. Plus when the Battlegroup is moving at a fast pace with the battlespace changing daily you didn't have the facility to transport huge quantities of water around with you.
HTH 110 D250 SE HT
110 USW SOLD
Post #181625 3rd Nov 2012 11:00am
leeds
Thanks! Thumbs Up
I was thinking along lines of Free Radical Chemicals/Compounds
Brendan
Post #181633 3rd Nov 2012 11:18am
excossack
Thanks for the info., some good reading.
I wouldn't say I was worried about the water as I can change the water with ease. It was more out of interest type question.
I would like at some point a stainless steel water tank behind the N/S wheel arch with a pump/tape attached for both drinking and washing hands. 1999 Defender TD5 110
Regards
John M0VAZ
Post #181804 3rd Nov 2012 9:41pm
ZeDefender
We use this stuff for camping when we're not sure about the water quality - keeps water drinkable for 6 months:
http://www.yachticon.de/Drinking-Water/Aqu...::927.html Tell someone you love them today because life is short.
Post #181810 3rd Nov 2012 9:58pm
leeds
Stainless steel water tanks in the wheel arch hold about 40 litres. Weight is low down and close to axle which are all good points. However they do not come cheap. Useful in a 90 if you are going on a long trip.
Alternatives include plastic tanks either on wheel boxes or between wheel arches. These are cheaper then stainless tanks
Various water jerry cans are available, however avoid the cheaer ones as they will split if dropped when full!
Another thing to consider are water bladders. Great advantage of these is that they do not take up much room when empty.
Brendan
Post #181819 3rd Nov 2012 10:29pm
excossack
I bet the S/S tanks don't come cheap. I was thinking around the 15 - 20L mark.
Plastic tank and bladders also have advantages.
Is there a plastic tank that will fit under the wheel arch ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #183055 7th Nov 2012 9:34pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
If you are really worried then you can buy a "Lifesaver 4000UF" which means you can treat dubious water in your own tanks or you can treat other water sources as you go - and thus not have the weight of drinking water in the truck (you must however have an emergency reserve if you're going anywhere where water of any description could be hard to find). You can treat up to 4000Litres for approx £120
To keep any water for longer I would not use the clear water containers - black plastic, stainless or plastic lined food grade jerry cans keep the sun off and remove one more source of energy for the nasties
Post #190074 1st Dec 2012 4:52pm
ZeDefender
Depends if you're going somewhere nice and sunny - UV is our friend:
http://www.sodis.ch/index_EN
As I said a few posts back the Lifesaver/AquaClean stuff is an essential Thumbs Up Tell someone you love them today because life is short.
Post #190100 1st Dec 2012 5:42pm
Merlin
Isn’t it a bit frightening to consider that all the water on the planet was there when the planet was formed and that we have been using this same stuff ever since?
Perhaps we are drinking dinosaur pee?
Merlin
Crying or Very sad
Post #190101 1st Dec 2012 5:53pm
leeds
Some interesting observations
70% of the earths surface is covered with water.
97% of water on earth is salt water which leaves 3% as drinkable water
Of that 3% 2% is locked up in the polar ice caps.
So that leaves 1% of water suitable for drinking for an ever expanding human population!
Amazing what you can learn from listening to the radio and then doing a quick google! Razz
Brendan
Post #190109 1st Dec 2012 6:07pm
GUM97
Steve Wright in the afternoon listener are we Brendan ? Whistle An engine to TDi for!
Post #190119 1st Dec 2012 6:42pm
