Home > Technical > How long does it take do do a Puma's bearings
TheWall
South Africa 2008 Defender 110 Puma 2.4 SW Alpine White
Hi,
How long should it take a LR Expert to do bearings?
Then also will cleaning the magneto take much longer? (Think it is called magneto, the piece in the wheel on the back wheels that is picked up by the ABS sensor.
Thanks http://banddc.blogspot.com/
Post #181201 2nd Nov 2012 5:46am
sense of adventure
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
Re: How long does it take do do a Puma's bearings
TheWall wrote:
Hi,
Thanks
To do it properly it takes anywhere between 40 mins and a hour per corner, depending on what tools, ie presses etc are available.
It takes me about 40mins a corner.
to clean the phonic Ring will take about 10mins per corner, it is only held in place by 5 m6 bolt
Post #181309 2nd Nov 2012 1:57pm
TheWall
Post #181310 2nd Nov 2012 1:58pm
