![]() | Home > Expedition & Overland > ISO Container/Shipping your truck |
Rather than turn it into a ![]() http://www.volvologistics.com/SiteCollecti...202011.pdf http://www.volvologistics.com/sitecollecti...202011.pdf |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
If we want to go all official as per the post above, the regulations state 3g loadings foward rear in a container 1.5g side to side you as the shipper have to get an engineer to do the maths or Land rover weighs 2 tonnes 4x 5ton ratchet straps will do the job at the correct angles. I always tie the body and compess the spings/ bump stops on air sprung motors. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
I think I'll drive instead
![]() Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
I think you would have to discuss this with any shipping company - but it does give good food for thought on what is best practise and knowing the right questions could perhaps help select the most appropriate shipper for you. |
