![]() | Home > Puma (Tdci) > 3 Weeks old now!!! |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 842 ![]() ![]() ![]() |
aaa
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Hi,,
Welcome to Defender2,, though you may be intrested in the bulletin for LR as below Date: 15th October, 2007 Bulletin No: LRHUB111 Circulation: Global Marketing, Lead Agencies, Operations, NSCs, Importers, Aftersales, Regional Agencies Dear Colleague As part of our commitment to continually improve our product and processes a study has been undertaken on improving the protection of the underside of the vehicle. The under body waxing was originally applied to Defender to prevent the underbody fixings, the chassis and the underbody panels from corrosion and stone chipping. In 2005, improvements to the chassis frame, fixings and paint process further enhanced the corrosion protection for the chassis area which resulted in only bare metal parts being treated to body waxing which were the most susceptible parts to surface corrosion in transit. A further improvement to Defender has now been developed which involves the fitting of two under trays to the underside of the vehicle which will provide the floor panels of the seat base with protection from stone chipping. In addition to the fitting of an under tray all Defender chassis will now be subject to the same processes in our paint facility as Discovery and Range Rover Sport. As underbody waxing is not designed to stay on for the lifetime of the vehicle, the result of these improvements will provide improved quality to the underbody of the vehicle as the fixings and the addition of the under trays means the vehicle can withstand corrosion and stone chippings. Therefore from mid to late October 2007, we will no longer apply the under body waxing. Once this change has been implemented I will communicate the effective vin number. Kind regards xxxxxxx@landrover.com California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
aaa
