![]() | Home > For Sale & Wanted > SVX headlamps |
Bodsy Member Since: 20 May 2010 Location: Shropshire Posts: 61 ![]() |
I assume they come with the bulbs? If so I'll take them. Will pm you my address. ![]() Cheers Ian Over on D3 |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
yep....DONE Putting Dreams on Drives at JLR Solihull..
These 80/100 bulbs, is it ok with std wiring or do I need to rewire with a relay?
300tdi 96 csw Over on D3 |
The light switch already often melts with the standard 55/60W H4's, so imagine 80/100W
![]() 80/100W H4 in main headlamps, with relay or not, they will be not road legal You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
sorry fella, only just seen this post, was'nt aware the bulbs were that wattage..... Putting Dreams on Drives at JLR Solihull..
Maybe not road legal in Switzerland but UK Vehicle Lighting Regulations states
Personally I think there should be requirements with a minimum and maximum light output as wattage has nothing to do with light output but is a measure of electrical power consumed! Brendan |
