![]() | Home > Td5 > Disco ECU into a defender? |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
A D2 ECU will work in any Defender td5. Just that some things (e.g. fuel gauge) won't be right, but the engine will run.
Injector codes are not too important. Even if incorrect, the engine will run fine. I suggest the issue is with the security re-learn as you stated. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
Got it running. Had a bad earth on the battery, which although was showing 12 or so volts, it had no current to it. and a fuse missing for the immobiliser (the fusebox behind the gearstick)
Bit of priming and away it went. Lots more jobs now to finish ![]() Last edited by diesel_jim on 17th Oct 2012 8:35am. Edited 1 time in total |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2955 ![]() ![]() |
well done Jim
