Home > Td5 > Split second loss of power
Geoff 90
Was driving down the motorway earlier pottering alone at 90kph and came up to a slow moving truck so indicated and went to move into the middle lane and went to increase acceleration when I went to do this there was a thud no power for a split second then back to normal. Didn't get a look at the dash to see if there was any warning lights. Just wondering if anybody has come across this problem before.
Geoff
Post #172992 3rd Oct 2012 5:26pm
leeds
Yes we have twice but it wasn't just a loss of acceleration, it was more a total loss of power. We had it in but needless to say it mistified all. Having said that, touch wood, it has been ok since.
Barbara
Post #172998 3rd Oct 2012 5:58pm
Geoff 90
Well yeah I would say it was a total loss of power like it had been kicked out of gear. Wasn't a pleasant experience anyways. Like you said touch wood it doesn't happen again
Post #173000 3rd Oct 2012 6:06pm
JWL
My Td5 will do it when doing a steady 65+ for a prolonged time, motorway/dual carriageway. I have put it down to coolant temperature rising, doesn't show on the guage but it happened last time to me driving back from the LRO Show at Peterborough. There was a cross wind, I've got 2x 8" spotlights in the A bar plus the radiators are in need of a good clean out of Salisbury Plain and Welsh mud. The effect is short loss of power, the temp guage and fuel guages drop to zero but all retuns to normal. Drive 5mph slower no problem but drive faster for 10minutes and it will re-occour if climbing a hill or accelerating to overtake.
Post #173005 3rd Oct 2012 6:17pm
TD5_90
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
Not exactly the same but similar symptom in the past. Check your waste gate actuator is not sticking. There is a good video from Bell AUto Services (sponsors of this forum) I think on you tube.
Post #173067 3rd Oct 2012 9:04pm
Geoff 90
Cheers td5-90 will do over the weekend alright
Post #173072 3rd Oct 2012 9:23pm
I had this which eventually worsened over time.. It was the loom under the rocker cover that had deteriorated.
Post #173074 3rd Oct 2012 9:35pm
Geoff 90
Was thinking it might be the injector loom alright but it was only changed a few months ago so hoping its not that. Would be nice to know what it was all the same tho
Post #173077 3rd Oct 2012 9:37pm
Laurie
Check your radiator if you've been offroading.
See.....
http://www.defender2.net/forum/topic14323.html
Post #173095 4th Oct 2012 12:59am
Porny
Site Sponsor
Not Pete's handy work... Whistle
My video is here Wink
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #173106 4th Oct 2012 6:25am
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Had it twice then it refused to start twice!!. Need 5 cranks to start, then second time it 3 cranks.
Dealer said it was all fine according to their computer when plugged in Rolling with laughter Rolling with laughter Rolling with laughter
They did indicate it maybe a wiring loom just 'wait and see'. They did check all earths and connections and so far it's been ok
Post #173108 4th Oct 2012 6:36am
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
If the turbo waste gate is seized it feels like the vehicle has hit a governor and a "surging" may be felt (it did on mine anyway). With the waste gate not opening, the turbo will be over boosting. The ECU will detect this and cut the fuel. As the boost drops, fuelling will then increase and the whole process starts again, leading to surging. If by loss of power you mean the vehicles speed starts to drop off rather than just lack of acceleration, I would look at it being something else. If it's just lack of acceleration then get some pliers or mole grips and follow Ians video.
Post #173126 4th Oct 2012 8:25am
randallised
Ireland 2005 Defender 110 Td5 XS CSW Java Black
Try the relay second from left slightly bend the spades with pliers makes a tight fit again. Had same problem good as new now.
Post #180234 29th Oct 2012 10:05pm
