![]() | Home > Technical > What's that button for? |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Hmmmmm, spot light switch, never thought of that- was going to fit an ejector seat
![]() http://www.youtube.com/watch?v=SPOFPj8iou8 Dual purpose Glyn ![]() ![]() |
Wouldn't work on mine.... My sunroof opening is not long enough for that...
![]() More importantly, what think, are those two switches (rear fog light switch and aux light switch with the #2) simply interchangeable? You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Glyn, no it's different.
The two switches (left for the rear fog, right for the front fogs) look the same but work in a different way. The switch for the rear fog is a push-push type. You can turn it on together with driving lights or high beam, but not with the parking lights only. If you turn the rear fog light on with the driving lights, and return to parking lights, rear fog goes off, and when turning the driving lights back on, it stays off, you have to again push it to turn the rear fog on with the driving lights or high beam. That is the standard LR set-up. This switch when turning it on, comes fully back to its rest position, only way to tell that the rear fog is on is by the orange light in the switch and on the dash. The front fogs switch which is optically the same is working differently, a push latch on - push unlatch off type. You can turn it on and the switch will latch on, and the front fogs will then stay on with either parking lights, or with driving lights. However front fogs will turn automatically off when switching from driving lights to high beam, and reverse again. When you turn this switch on it will latch into a 3 mm deeper position. When unlatched it comes back to level position with the other switches. So I can independently from the rear fog, turn the front fogs on with either parking or driving lights, but not with the high beam. And I can turn on the rear fog only with the driving lights or high beam, or with both the driving lights and the front fogs illuminated simultaneously. I think that is the correct legal way of wiring them. And as both the here discussed aux switch with the #2 printed on it (as in dgardel picture), and the switch for my front fogs are of the push latch on - push latch off type, presume they are indeed interchangeable. HOPE SO ![]() ![]() Hope I was clear with how I described it. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Your front fog switch sounds IDENTICAL to the switch with the 2 on it other than the actual symbol.
The one with a 2 on it (as I have) has the same function as yours latch on or off..... but I have it for spots so works on main beam apposed to dipped (but that is wiring not switch). The actual plug behind the one with a 2 on it is identical to the rear fog light plug. Glyn ![]() ![]() |
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
you can change over the switch fronts and leave the main body alone 2002 90 Td5 Station Wagon
![]() ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Yes
![]() Changed the switch fronts when I put the work light on the 110, fiddly but can be done. Biggest problem will be getting the different switch front, not sure you can get them on their own. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
just came across this looking for a spotlight switch ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Hmmm that blue paint in the background looks familiar too.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
poor old td5
