Home > Wheels & Tyres > spare wheel on pickup...
tom 90 pickup
im wanting to put my spare wheel on the back door of my 90 pickup so i can advertise
my company name on the wheel cover.
i havent seen any 90 pickups with the spare on the back, is this possible? how do i go about
fixing it on and will it be a pain in the ass and get in the way loads there?
Post #171923 29th Sep 2012 11:21pm
ibexman
Hang the tailgate on side hinges and get a decent swing away Thumbs Up
Post #171932 30th Sep 2012 12:22am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
MIB make one. Retains in the same way as your tailgate on the left so I don't think you would need to change the way it's hung if you don't want to side hinge it.
Post #171949 30th Sep 2012 8:37am
tom 90 pickup
I had a look on MIB website but it didnt have anything about it so i guess i am best to call them up...
Hows the best way to go about changing where the door in hung? do u need new hinges? how will the door then stay shut etc..?
cheers
Post #171954 30th Sep 2012 8:52am
leeds
Is this what you are after?
Brendan
Post #172170 30th Sep 2012 8:09pm
tom 90 pickup
yeah something like that... wasnt sure weather theres a way to just mount it on the tailgate without having to buy the big ungly side hinge thingy lol
cheers
Post #172218 30th Sep 2012 9:28pm
tom 90 pickup
has anyone used a small spare wheel mount and fixed it to a pick up tailgate? would this work? any pics or advice welcome.
cheers
Post #172362 1st Oct 2012 10:52am
The easiest way to make a side hung tailgate is to cut off the anti-luce loop on the drivers side and fit two standard rear door hinges. The anti-luce on the passenger side remains as the latch. A slightly more refined way is to cut down a rear door, as this way you get a nice latching handle (and lock, FWIW).
There's no reason why you couldn't bolt a standard rear door wheel carrier to either. If you go down the 'cutting a door down' route then it might already have one fitted. Bear in mind though, that the weight of the wheel will only be supported on those two hinges. If your truck is a normal runabout then that might not be much of a problem. However, if you're into serious playing then that weight will eventually break something. It's for this reason that rear doors are now fitted with three hinges rather than two from Series Land Rover days. It's also why people are recommending swing away wheel carriers, which carry the weight instead.
A swing away carrier doesn't have to be expensive. Whilst there are some very nicely engineered examples out there that open with the rear door or avoid drilling the bodywork, for your application then a simple one from Paddocks for about £80 would almost certainly suffice. Darren
Post #172368 1st Oct 2012 11:18am
tom 90 pickup
thanks again darren, as you can prob tell im pretty new to the whole defender scene etc so the help is grate.
im not going to be doing much off roading or playing around with my defender, just mainly using it as a daily work van. Im not to fussed on the tailgate being hinged as it is from the bottom so would i be ok to leave it as it is and to just bolt a sparewheel mount on? Im aware that it will be heavy to open once i have fitted the spare wheel but as the tailgate is on chains i dont think it will be a problem...? let me know what you think..
cheers Very Happy
Post #172383 1st Oct 2012 12:21pm
Glynparry25
Tom, I am guessing you want to keep the tailgate as a 'drop down' where everyone is talking about changing it so it opens sideways?
Either as mentioned above- which is the safari-equip one. There is also the 'Sonic spare wheel carrier' which bolts only to the chassis so you open the spare wheel and then drop the tailgate.
Value for money, yes you could just bolt a Discovery spare wheel carrier straight to your tailgate. This will make it VERY VERY heavy though. Easy to open, and the chains will possibly be able to hold it (well the chains will but maybe not what they are bolted to) but then when it comes to closing it will be a PITA.
Glyn Dog Sheep
Post #172395 1st Oct 2012 12:38pm
The standard tailgate is not strong enough to have a spare wheel hung upon it, and if you wanted to do this your best bet would be to fabricate a replacement tailgate with reinforcement. You will also (probably) need to beef up the hinges and antiluces, and certainly the two stays.
In the good old days Land-Rover used to fit a variety of "tailgate-mounted" kit on vehicles, such as PTO driven compressors and generators etc. These usually consisted of frames which picked up on the tailgate mountings but the builk of the weight was inside the buck, and of course the old hinges etc were much stronger than the "value-engineered" modern equivalents.
So it can be done, but may be more work than using a swing-away type carrier. Also don't underestimate the weight of a the tailgate and wheel, it won't be easy to open or close.
Post #172397 1st Oct 2012 12:41pm
PS, apropos Glyn's response. The Sonic3D (now Allisport) wheel carrier does not require any drilling to fit, and is very easy indeed to operate. It has a further advantage that it can be adapted to work with an IW canopoy's full width flap, which is often a problem with inferior carriers. I have had one fitted for the last two years and rate it as one of the best upgrades I have done.
Post #172399 1st Oct 2012 12:44pm
fixit
Even if you could fix on the tailgate to still hinge down you would need to mount it very high
And if you plan on having a trailer behind it won't be a lot of good
Just a tailgate is enough of a pain in that situation
A swing away with a drop down tailgate is also a none starter with a trailer as you cant swing the wheel back before you drop the tailgate down as the swingaway hits the jockey wheel
Making them hinge to the side is the best option
I made a swingaway and bolted the tailgate to it for a series 3 some years ago as it ment they both moved together
And it saved the price of safari hinges and the hassle of needing to open one then the other every time i needed to get in
Post #172469 1st Oct 2012 5:38pm
Glynparry25
BRAINWAVE......... Tom, you are fitting a roof rack......... Just the place to mount your spare out of the way Thumbs Up
Glyn Dog Sheep
Post #172476 1st Oct 2012 6:16pm
mk1collector
There are some on eBay now for.......
Wait for it........
A discounted limited time only offer of £750!!!!!!!
Hahahahaha
I bet they sell loads
Post #174611 10th Oct 2012 4:15pm
