Home > Td5 > Trouble selecting gear
Page 2 of 2 <12
mk1collector
Is evo 1 a brand or a grade of oil? Or could anyone put up a link as I find it hard to get into first.
Post #182902 7th Nov 2012 4:06pm
TD5_90
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
http://shop.difflock.com/difflock-evolutio...-p-51.html
Web address above but probably not links or clicky?
Evo1 is a brand of oil from Difflock. I have used twice now, had standard grade gearbox oil put in at recent service but when the colder weather came so did sticky 2nd! I have reverted to evo oil and gear change is like silk Very Happy
Expensive but it has worked for me and it lasts longer so not so expensive in the long run.
Regards
Post #182925 7th Nov 2012 5:00pm
mk1collector
Great stuff, cheers
Post #182963 7th Nov 2012 7:12pm
df1
Adjusted the two springs on the gear lever this evening, I noticed some wear on the housing that the pins slide up and down in, has anyone replaced/repaired this ?
I'd imagine it would tighten up the gear selection another, although adjusting the springs was a great improvement.
Post #182966 7th Nov 2012 7:20pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Hope your right, have had a crunching 2nd gear for years, especially when cold. Have just ordered 3 litres of the Evo 1 hope it does the trick ! 2007 TD5 90 Hard Top
Post #183064 7th Nov 2012 9:50pm
Page 2 of 2 <12
