![]() | Home > Technical > rear slide window on my pickup |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 ![]() ![]() ![]() |
You will find that the seal has a central bead to it. Look around the edge of the seal for a smartly cut join in the rubber. Stick something small in there and pry it out and you will see it peel out the middle a bit like one of those tearaway strips that you tear to get into a pack of biscuits.
Once that is out, you will find the seal and windows come out much easier. Just remember to take them out wearing a pair of rubber gloves, as they will give you good adhesive properties to the glass. I am sure someone will have a pic along sooner or later. Adam |
