![]() | Home > eBay & Bargain Spots > Rock sliders |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Hi and welcome Undergroundfrog......
have a read of this http://www.defender2.net/forum/topic5309.h...der+flares when i got mine you could only get them in the US.. just done a search for you and you now can get them over here ![]() http://www.specialist-leisure.co.uk/full-l...xi-flares/ NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Don't underestimate Fekete's modesty - it's not that easy to do a good job without bulges etc. (fortunately someone bought the arch I practised on, despite all the holes)
![]() @ Fekete - yours look better every time I see them ![]() But shout it at them in German because life is also terrifying and confusing... |
Undergroundfrog Member Since: 27 Jan 2013 Location: Herts Posts: 31 ![]() ![]() ![]() |
Great write up and looks very nice indeed, I'm sick of the mud being flipped over the side of the bodywork, plus that little extra looks great, I'm glad I've joined now seeing that . ![]() Thanks for the link, I may have to go slightly wider as I have 2" tyre protruding past the arch. |
Thanks ZeDefender, ![]() Undergroundfrog, your welcome. NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
@ Fekete
Actually looking at your picture you've got the same tyre overlap. Has yours got the metal rod inside the extensions? I see you took the arches off to do the fitting, do you recon they can be fitted in situ? |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Mr Frog,
Once you have a price from Specialist-leisure stick it up on here as there is a small place here (in Cyprus) that sell those extensions at maybe a better price- postage is reasonably cheap too. Last time I asked Specialist-Leisure for a price it was over 60% more than the retail in the US!!! Glyn ![]() ![]() |
They are really tricky to be honest but could be done with the arch in situ... it's really easy to take the arch off and get a better job as you haven't got much to play with.....I haven't got the rod inside as there quite stiff anyway.... the only reason i fitted them was i had a keen Copper on me case ![]() Glyn, your probably right on the price thing...as said got mine over in Canada when i was there so was a lot cheaper ![]() |
Many thanks both
![]() Glyn, please pm me details for future use, as I may be going there for holiday ![]() |
