Home > Puma (Tdci) > Puma engine cuts out |
Check the main relay socket and the fuses sockets/connections Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
14th Aug 2012 10:01pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2443 |
With an inboard compressor into the fuel tank and open bleeding valve. There is also a special manual pump (search on this site or google it) Puma 110" SW ............................................................. Earth first. Other planets later |
15th Aug 2012 2:24am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2648 |
Sounds like the engine is not getting enough diesel? Drop the tank and check that the fuel pickup is not clogged - not uncommon for this to be blocked especially if you have filled up with some dodgy diesel. Also check the fuel filter (in the driver's side rear wheel arch) -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
15th Aug 2012 8:28am |
