![]() | Home > Maintenance & Modifications > Grey trim pegs part No.? |
Our dealer can't find them on the locator,is that the same with yours ? 2.4 90 XS
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
To be honest Grockle, I haven't even tried. I'm going to now though. Thank you.
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
dm,we know them as fir tree plugs,which need to be carefully drilled out, but what seb is talking about are scerw covers to match the grey window trim
![]() 1968 1/32 scale Britains 109 Pick up. |
Hmmm. I'm talking about things that have a flat 2-3cm grey head and a about 5-6 cm of plug that has flaps (?) that all face back so that the thing flies in and refuses to come out. Sounds like Christmas Tree Plugs would be a brilliant name for them.
Didn't get round to calling Lookers in Chelmsford. Will see over the w/e. I'm off to Eastnor for my freebie 1/2 day on the track this weekend. Might pop in to Hereford Land Rover and speak to someone who actually knows about Defenders and doesn't spend all day playing with RR Sports! I fancy starting a book on how much people think LR would charge for the plugs - i'm betting on £2.00 each! Place your bets! |
Sounds like the same things, the are on the rear of the door near the catch and about 2" long when removed. I got bot mine out OK when I fitted the cargo barrier. There's always the delear.
http://www.wclco.com/pdf/plastics/010.pdf 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
part number MWC5763LOY Fastener Fir-tree from microcat
Brilliant job, thank you ![]() I'll let you all know how much they're charging for them, so we can all have a good laugh! |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
![]() ![]() ![]() '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
That's for 10 hopefully
