Home > Technical > Help... |
disconnect the battery again
leave it. re connect after 10 mins. try again with a good battery. if doing the same call landrover assist |
11th Aug 2012 10:09am |
haworthj Member Since: 01 Nov 2010 Location: Sussex Posts: 178 |
Thanks Marcus. Seems to have done the trick.
James |
11th Aug 2012 2:09pm |
oh no, just tried again. still the same problem....with the key in the ignition, i can start the engine, but the rev counter doesnt work, the battery light is on...... argh!
11th Aug 2012 3:24pm |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1382 |
Alternator on its way out? Euro-Leafing to infinity and beyond.....
12th Aug 2012 8:50am |
This is a known issue with the Puma and it is an ECU fault. If you can read the DTC's stored check for P068-A being logged as a tested DTC within the EMS. P068-A appears quite often if the OBDII socket is used to power a diagnostic tool or scangauge/ultragauge etc. However in conjunction with the Temp gauge in the red and the engine in limp mode this points to the ECU failing. If you are in warranty call out LR assist as long as the Puma is still showing this fault.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I have had the same symptoms a couple of times but it is easily checked for a fault in the harness by following the tech bulletin. My issue was the OBDII socket and after I rectified the issue the fault has yet to reappear. Point to note not mentioned in the above bulletin is that if the fault happens with the engine running it goes straight into limp mode but no MIL will show and you will struggle to get above 25mph. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
12th Aug 2012 10:04am |
callummb2 Member Since: 24 May 2021 Location: staffordshier Posts: 10 |
HI could some one send me the teck bulletin on how to check the wiring as mention in Lorryman100 last post.thanks
27th Nov 2021 10:50am |
The tech bulletin is actually contained in Lorrman100's last post. Darren
28th Nov 2021 4:14pm |
