Home > Puma (Tdci) > Some other wires needing protection |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Found a couple other wires/break pipes and cables needing protection from chaffing. Stuck some left over sprague tubing to reduce possible damage.
Click image to enlarge Click image to enlarge Click image to enlarge Puma 110 - gone Series III 1973 - going strong |
10th Jun 2009 7:22pm |
I suppose I should have explained better.
The group of wires running past the vacuum break cyliner on the outboard side were chaffing on the lip of the booster. These wires are merely taped together with insulation tape. The next is some sort of cable (maybe the bonnet release) which runs past the inboard side of the vacuum break cylinder and then straight next to the heat shield - mine rubbing against both above items. The other is the now "bent away" break pipe only mm away from the heat shield now rubs against the other break line below the heat shield. I put some sprague tubing with a cable tie over that section of break line also. Hope this helps some of you Regards James Puma 110 - gone Series III 1973 - going strong |
11th Jun 2009 5:29am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Thanks CL, will have a look 2.4 90 XS
12th Jun 2009 9:33am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
12th Jun 2009 9:39am |
D.M - 12 days for you 14 sleeps for me until Botswana - can't wait. First big trip we are doing. Hope my new radiator hose arrives by then
Goood luck with the crawling about the fender on the weekend. I have to spend mine at work assembling a troublesome propeller shaft that was a can of worms when we opened it up. Click image to enlarge Puma 110 - gone Series III 1973 - going strong |
12th Jun 2009 10:18am |
Almost there now
16th Jun 2009 8:41am |
