Home > My Defender > 4x4 Overlander Vehicles
Page 1 of 8 12345678>
leeds
Recently took our Puma to see our friend matthew at MKS Classic and Sports in Leeds Thumbs Up
Just a few minor changes Whistle
Off come the old Safari Equipe standard wheel carrier. Nothing wrong with it.
New single pivot wheel carrier was fitted.
Only problem was that we had to drop the wing tank to get at the back of the rear cross member.
Whilst at it we changed the bumperettes for these. Before anyone comments same bumperettes different vehicle Razz Just a better photo as have not photographed ours yet!
Whilst at it we changed the extra work lights/reversing lights to these
Also an upgrade on headlights to
Barbara had been pestering me for a while for a new steering wheel
Have a few other little mods to do, including a remap. Will have to have a little chat with some of the other forum sponsors Whistle
Our red 110 300TDi had a little mod as well
Red sand and broken glass still embedded from our little Australian trip.
Brendan
Post #157292 22nd Jul 2012 12:02pm
bell-auto-services
Nice mods Brendan Smile Im sure I can help you finish off the bits it needs with a remap Smile
Pete
PS what steering wheel is it ?
Post #157299 22nd Jul 2012 1:50pm
bob neville
I'll answer the steering wheel question for you Pete, Brendan is probably sunning himself Laughing
It's a Raid Nero, I have one fitted as well. Brendan supplied mine (from Nak.
Think there are some pictures in my gallery.
Here you are, I have the LR centre now, it was still in transit when I took this picture.
2013 Defender 90 CSW - sold
Post #157307 22nd Jul 2012 4:35pm
leeds
Yes Bob is right is right. About the steering wheel, not about sunning myself as have been down at the unit all afternoon.
We will have to have a chat over a beer at Billing Mk2 Pete. Would be ointerested to hear how you are going to remap our 110 300 TDi Razz
Brendan
Post #157319 22nd Jul 2012 5:44pm
dgardel
Italy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #157366 22nd Jul 2012 8:47pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I like the work lights, do you have any more details?
Post #157378 22nd Jul 2012 9:06pm
davew
Do you have a pic of the back with the tyre mounted on the new carrier ?
It looks to be very high up from the pics you've posted, is it any higher than a standard mount ?
Do you need me to test one on a trip around Australia ? Smile
Post #157384 22nd Jul 2012 9:31pm
leeds
OK not photos of our 110. The single pivot wheel carrier can be mounted in a high position, could be useful if you have an Alko type towing hitch, or a low position
High position
Low position
The actual visibility through your rear window will dependent on position of wheel carrier and the overall diameter of tyre..
Have already tested a Safari Equipe wheel carrier around the Australian outback as you know DaveW.
If you want to have a look at some photos etc, I suggest you look HERE Thumbs Up Whistle Rolling with laughter
Brendan
Post #157386 22nd Jul 2012 9:45pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
who did the one with the 95mm brake light in the middle, i quite liked that. Putting Dreams on Drives at JLR Solihull..
Post #157517 23rd Jul 2012 6:28pm
davew
That looks very high in the "low" position. overlaying a pic of the standard LR wheel carrier with that shows the standard one around 4 inches lower than that one.
Post #157529 23rd Jul 2012 7:17pm
JSG
Yes - it is. I had a look at Big Russ' carrier which was on the lowest setting and it blocks the rear view - he is thinking of getting an adaptor made to lower it IIRC. John
2011 Tdci 110 CSW XS
Post #157542 23rd Jul 2012 8:05pm
leeds
Yes in the low position some people might consider the wheel to be too high. However it does allow attaching trailers/caravans with the Alko type hitches to work better.
It would be possible to get a different plate mounted on the carrier so that in the low position the spare wheel was lower, however swop the carrier over and in the high position it would be even higher.
The difficulty is there is not one item which will suit everybody as some compromises have to be made.
So if people want things sorting out to theit own requirements give me a shout and I will always see what can be done. However their may be cost implication as well as delivery time implications.
Brendan
Post #157748 24th Jul 2012 5:44pm
T1G UP
who makes it?
Post #157752 24th Jul 2012 6:26pm
BigRuss
Safari equip tig Thumbs Up
Brendan is right you can't please everyone but you can get rather close to it.
I don't have any trailer/tin tent that has an alko type hitch so I don't need the extra height. I do have ever plan on changing my tyres to a 285 or a 255 which will give it an exta inch but will still retain a 16 inch rim, some will have it adaptd to sit lower to meet my requirements when I get round to it Whistle
The reason I went for this one was because I wanted a wheel carrier that was connected to the rear door but all the weights was on the rear crossmember, I didn't wasn't to drill any holes and I wanted to fit a set of rear bumperettes. Lucky of me this one met every requirement Mr. Green Russell
2011MY 110 XS USW Black
Post #157779 24th Jul 2012 8:05pm
T1G UP
yes i don't want any extra holes in the 110 either.
Now i have the standard LR tow set up i did have to put my dads caravan on the 110 with the rear door open as he has the alko hitch thing with a damper ? built in
Post #157819 24th Jul 2012 10:08pm
